Quickdraw won't start
I recently purchased a high rev quickdraw off of a buddy of mine. He said it ran great last year, but has not started it yet this season. I went to start it earlier today, but I got nothing. The engine is getting plenty of fuel, but it is other things I am worried about.
1. I took out the spark plug and made contact with the top and side of the motor, and I saw no spark. Does this mean the coil is bad?
2. The pulse fitting from the carb has what looks like fuel in it now. Is that normal?
The carb I am using is a modified 644, with the factory setting on the low and high speed needle, 1.5 turns out on each. Any help would be greatly appreciated.
Sounds like the coil. Try the red one first. Gap to .012 inch clearance to the flywheel. The red coils are like on/off switch it seems. Sometimes it works and may just quit. Though, just recently we had 2 in the last few months run erratic on the dyno. Switched the red coil out and ran fine again, put the old one on and it stuttered on top end bad. On the carb, the clear pulse holse comming from the engine to the fitting on the carb cover is the pulse hose to activate the fuel pump inside. The carb needles we set here if we had the carb and motor here. If not? The needles will be set at starting points and may need to be adjusted.
Todd
Quickdraw
Todd
Quickdraw
The coil that I have now is the red coil. Should I get a new one anyway and try it? If I hold the park plug next to the motor, should I see a spark? Since the clear hose is a pulse hose to activate the fuel pump, I take it that it is ok to have fuel in the line? Is a good starting point with that carb 1 1/2 on each the high and low needle settings? Thanks again for the help.
If I hold the spark plug next to the motor, should I see a spark? Since the clear hose is a pulse hose to activate the fuel pump, I take it that it is ok to have fuel in the line? Is a good starting point with that carb 1 1/2 on each the high and low needle settings?
ok, 1 the coils don't go out over night.
2. always try a new plug first, it is the cheapest component of the electrical system.
3. since it was sitting I would guess a stuck ring, what kind of oil was your friend using? Anthing but synthetic could stick a ring. what kind of compression does it have?
4. check the ground to both coils, a bit of corrosion over time (sitting around) will degrade the grounding connection.
5. QD's are notorious for flooding easy and 644 carbs don't help the situation.
Pull the plug, crank it over to clear the fuel, new fuel and after you checked the ground and I bet it will fire!
The spark is real weak and hard to see sometimes. Try checking in a dark or not that well lighted area.
I would like to know who? The customers who we talk to say they start easier than their Zenaoh. Put finger in carb to choke it. Pull rope till you have fuel on finger tip. Remove finger and pull. Usually takes like 2 to 3 pulls after choked and it fires right up.
On the carb. Do not set the needles till it sounds crisp on the shore. You wil be too lean when it hits the water. 644 start with like 1 3/4 on the low and 1 3/8 on the high. Please note though. These are only starting points and may need to be adjusted. You will see some fuel pulsate back and forth when running. Don't worry about it. It is fine.
If still can not figure out. Please call us.
Todd
Quickdraw
MO
Make sure the plug is not wet, if its ok and youre getting fuel when you choke the carb it should fire. If is dosent it could be red coil, grey coil, plug. Sometimes the ring will stick and leak off compression but they will normally fire if you put some Corrosion X in the cylinder then try to start. Give Quickdraw a call Todd can help you out.
Dear all
I had a QD engine in Taiwan. But I couldn't buy the spare parts from internet. Can anyone let me know where to buy?
Thanks in advance!
Bono Wang
Thanks in advance!
Bono Wang
