fuels
fuels
hi just wonderd what would be the best make and percent of fuel to run my savage 4.6 on i was on 20% cool power
thanks jamie
thanks jamie
RE: fuels
just about any good brand name fuel will work, but if your using power i'd just stick with it, and anything from 20-30% nitro will work, try not to change it though.
RE: fuels
ORIGINAL: maritimeracing
thanks jamie
thanks jamie
RE: fuels
ok thanks alot i will go down my lhs and see what they got i was thinking around 20% i cant get the same fuel besuse the shop i got it from has closed down if i change brand would it be leaner or richer as i was running it quite rich just to be on the safe side
RE: fuels
ok thanks for advice so if i change % would i have to change nedal settings ?
but if i only change brand of fuel i wouldnt have to ?
thanks jamie
thanks jamie
RE: fuels
^^ Don't know but I will say that O'Donnell's and Byrons are the best and most widely distributed in the hobby. I've tried a few, and Byrons is definitely my top pick without any doubts.. I've heard great things about Nitrotane/Rocket Science/Maxy's/Wildcat/Trinity, but none of them are available in my area. And since I get any fuel here for $20, why should I switch Remember when picking fuels, always pick the RACE version.. Never pick the RTR or Sport versions because they are loaded with oil. Stay away from Traxxas fuel, waay too much oil. Most others are fine to run, pick your percent and run it. I've run 20% since I started almost 5 years ago, just pick what you want
VT
RE: fuels
ORIGINAL: rcnitrohead
holy (insert profered curse word here) you guys can get GALLONS for $20 damn i'm screwed up here, a gallon of traxxas top 20% goes for $35 and thats all my lhs has
KS
RE: fuels
I guess I have been burning 52 dollars a gallon.... never looked at it that way before. Maybe I should try something else. I use [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNE15&P=7]Trinity 35 percent[/link] most of the time in my Piccos, 12 percent oil. It works super, but apparently costs me much more than I thought. [8D] BB
RE: fuels
ORIGINAL: rclugnut10
Byron and O'donnel gallons both go for 26-28 bucks here. But what's REALLY crazy, is the 15% powermaster fuel I run in my little Evader.. 15 bucks a gallon! It's not the most powerful stuff in the world, but it gives a consistent tune and is CHEAP!!
