R/C Setup And Tuning Guide Covering Just About Everything.
Hello Guys,
Here is an R/C setup and tuning guide covering just about everything. These links are in MS Word format and some versions of MS Word may throw off the pictures with the text. I copied this information from different websites on the Internet and placed them in MS Word using MS Office 2000. I also made spelling and grammar correction but know there are still some spelling and grammar errors. I made printed copies of all this, along with all PDF files that pertain to the R/C vehicles I run, placing them in clear plastic sheet protectors, locked into a three ring binder. This works great when Iām at the track or home. I hope you guys enjoy this and get as much uses out of it as I have.
Temptation.
1. 1.00 RC Nitro Engine Break In Guide And Tuning Basics
http://www.keepandshare.com/doc/view.php?id=583924&da=y
2. 2.01 RC Suspension Tuning
http://www.keepandshare.com/doc/view.php?id=583925&da=y
3. 2.02 RC Wheelbase Tuning
http://www.keepandshare.com/doc/view.php?id=583926&da=y
4. 2.03 RC Ride Height Tuning
http://www.keepandshare.com/doc/view.php?id=583927&da=y
5. 2.04 RC Toe In or Toe Out Tuning
http://www.keepandshare.com/doc/view.php?id=583928&da=y
6. 2.05 RC Camber Tuning
http://www.keepandshare.com/doc/view.php?id=583929&da=y
7. 2.06 RC Caster Tuning
http://www.keepandshare.com/doc/view.php?id=583930&da=y
8. 2.07 RC Shock Angle Tuning
http://www.keepandshare.com/doc/view.php?id=583931&da=y
9. 2.08 RC Spring Preload Tuning
http://www.keepandshare.com/doc/view.php?id=583932&da=y
10. 2.09 RC Shock Damping Tuning
http://www.keepandshare.com/doc/view.php?id=583933&da=y
11. 2.10 RC Droop Tuning
http://www.keepandshare.com/doc/view.php?id=583941&da=y
12. 2.11 RC Anti-Squat And Pro-Squat Tuning
http://www.keepandshare.com/doc/view.php?id=583942&da=y
13. 2.12 RC Kick Up And Anti-Dive Tuning
http://www.keepandshare.com/doc/view.php?id=583943&da=y
14. 2.13 RC Ackerman Steering Tuning
http://www.keepandshare.com/doc/view.php?id=583944&da=y
15. 2.14 RC Sway Bar Tuning
http://www.keepandshare.com/doc/view.php?id=583945&da=y
16. 2.15 RC Roll Center Tuning
http://www.keepandshare.com/doc/view.php?id=583946&da=y
17. 3.00 RC Tire Handling
http://www.keepandshare.com/doc/view.php?id=583947&da=y
18. 4.00 RC Off Road Tire
http://www.keepandshare.com/doc/view.php?id=583948&da=y
19. 5.00 RC Foam Inserts In RC Tires
http://www.keepandshare.com/doc/view.php?id=583949&da=y
20. 6.00 RC Car Battery
http://www.keepandshare.com/doc/view.php?id=583950&da=y
21. 7.00 RC Introduction to the RC Battery Charger
http://www.keepandshare.com/doc/view.php?id=583952&da=y
22. 8.00 RC Why a RC Speed Controller is needed
http://www.keepandshare.com/doc/view.php?id=583954&da=y
23. 9.00 RC R/C Car Electric Motor
http://www.keepandshare.com/doc/view.php?id=583953&da=y
Temptation.
RE: R/C Setup And Tuning Guide Covering Just About Everything.
Not bad. There is a ton of info out there to figure out how to set up your car, including RCU.
Here is a fairly recent book that has just about everything you'll need to know in it. It covers all of what you have posted and more.
http://search.barnesandnoble.com/The...323984/?itm=10
Whenever I need help, I look through my car manual for suggestions. Just about all of them have pages that can help with setup. The best thing to do is experiment with different setups and see what works for your driving style.
http://users.pandora.be/elvo/
one more
one more
