Removing One-Way Bearing
Old 05-26-2008, 06:08 PM
USMCREVO
Default Removing One-Way Bearing
I seem to have the slipping one-way bearing syndrome with my EZ Start. The EZ start motor spins (whirrs) but the engine sputters every couple of seconds. I have seen on different posts how to clean the one-way bearing, but I can't find how to remove it. Any advice?
Old 05-26-2008, 06:49 PM
rcnitrohead
rcnitrohead's Avatar
Default RE: Removing One-Way Bearing
To be honest, I forgot how the assembly looks on Traxxas trucks since my T-maxx has been sitting in my basement for the last year, but if you have access to it, spray some degreaser (any household degreaser, even oven cleaner) and it will work like a charm Tom.
Old 05-26-2008, 07:20 PM
futureboy1969
4 screws on the back of the engine. ez start come right off. pull out the bearing ,clean it w/nitro spray the oil it w/synthetic motor oil. that keeps it from sliping
Old 05-26-2008, 07:45 PM
rcnitrohead
Don't oil it, thats what makes it slip!
Old 05-26-2008, 07:56 PM
Mspeed
I have always oiled my oneways with 5w-30 synthetic like traxxas recommends. News to me if it last longer without oiling? Wondering if it wears them out quicker too?
Old 05-26-2008, 08:34 PM
systemlord
ORIGINAL: rcnitrohead
You forget that oil from the fuel reaches the one-way bearing from the crankshaft, everytime I take my roto start off all my engines I always see some oil from my Trinity's Monster fuel.
Old 05-26-2008, 09:29 PM
rcnitrohead
Thats the point, oil will get there anyway so there is no point to add fuel for the fire An OWB can never be dry unless it is external and very well sealed off.
Old 05-26-2008, 09:34 PM
matts6887
matts6887's Avatar
ORIGINAL: USMCREVO
3 screws that hold the ezstart gear case on is what holds the gear case in place; simply take the engine off, then take those 3 screws out to release the 2 halves of the gear casing where the one way sits, then take some denatiured alcohol and let it soak for a few hours or so, then dry it off and re-lube it with a after run oil....also while at it clean the starter shaft with den. alcohol and re-lube that lightly as well...
Old 05-26-2008, 10:45 PM
USMCREVO
Thanks guys. Almost seems too easy! Any opinions on the Tigerdrive since my EZ start will be off anyways?
Old 05-26-2008, 11:20 PM
systemlord
ORIGINAL: USMCREVO
I use the 90 degree Tiger Drive and I like it a lot!
Old 05-28-2008, 05:12 PM
USMCREVO
YUP, that was the problem. Dunked the bearing in denatured alcohol overnight, lubed it with 3 in 1 Oil, and reinstalled. Works like a charm. Thanks everyone. Im still thinking about the Tiger Drive option for when the EZ Start permanently dies though.
Old 05-28-2008, 06:44 PM
remz817
yeah haha w/e u do dont oil it. But i had the same problem. I cleaned it a few times but still no result in starting. So i just went out and bought a new one.
Old 05-28-2008, 07:09 PM
matts6887
matts6887's Avatar
ORIGINAL: remz817
Sometimes u have no choice but to get a new one; especially if u have tried cleaning the bearing and it still slips...
