Can someon explain brushless motors to me PLEASE!!!!!!!!!!!!!!!!
Ok as Im sure you all know by now Im running a Losi XXX-S. Im considering going from a brushed motor to a brushless but I have NO experience with brushless motors so Im not sure what to look for to find a fast one. Ive noticed that brushless motors dont go by turns like brushed does. With brushed the lower the turns the faster the motor is. What makes a brushless motor faster. Any help would be appreciated. Thanks.
RE: Can someon explain brushless motors to me PLEASE!!!!!!!!!!!!!!!!
I highly recommend buying a copy of the latest magazine buyers guide...can't remember which mag has it out now and my copy isn't handy...but it should be the only one on the shelf. I was new to all the brushless, LiPO super tech too. Most of my RC experience over the years was with Nikko and Tyco! There are some great sections in the beginnin where they tell you all about brushless vs brushed...details on LiPos..and a few other good articles. For brushless the higher KV rating the faster they are. I put a Losi Xcelorin 4800KV brushless/ESC combo in my XXX-T CR and it is stupid fast with a 11.1V LiPo. I wasn't used to the speed and burned off the antenna of my new SR31300 receiver when I was making a return run (my 1st with the new setup). I coming in at a good clip and figured I'd floor it...wheelied right over and skidding to my feet. I think the 4800 is lowest in Losi's Xcelorin BL line and I have to run the ESC at 50% and low motor timing just to keep control of it!
Ok thanks. Ill look into that motor\esc combo u have. I might as well use a losi with a losi right?
thats what i did and im doing good so far, i have to make alot of adjustments to my driving and to the esc to harness the power. if you are going to go brushless and lipo, make sure you have a temp gun, heat is the killer. if you dont have a temp gun, use your fingers, at its hottest point you should be able to hold your fingers on motor for atleast 5 seconds, i do not recommend this if you have nerve damage and barely feel pain anyways because you could melt your fingers off if its too hot. I'm still learning pinion size compared to what speed and stability i like, but make sure you get it right the first time, stuff is expensive and its worth the extra time looking to it before buying.
that whole finger trick really only works with brushed motors. but like you said, the REAL good thing to do is buy a temp gun. in my experience with brushless motors, i couldn't hold my finger on the motor for longer than 2 or 3 seconds. I freaked out and bought a temp gun to make sure I wasn't burning up the motor. turns out, it was only 145 degrees and the motors safe limit is 200. And you don't HAVE to buy a losi brushless system just cus your car is losi. Any system would work. One thing you want to decide, if your racing your xxx-s you should check your track for brushless regs. most races consist of "sensored" brushless systems. Basically there are extra wires from the esc to the motor to sense the position of the rotor so it can smoothly initiate power output. With "sensorless" systems, the ESC uses some algorithms (i don't know the specifics) to sort of guess the rotor position at startup. With the new technologies, and as long as you have good batteries, you can hardly tell a sensorless is guessing the position cus there is hardly any more cogging. some systems you might want to look in to
http://b-p-p.com/proddetail.php?prod=c_MambaMax5700
http://b-p-p.com/proddetail.php?prod=e_MambaMax7700
or you could just get the losi that was mentioned before, but i was just stating that you aren't limited to that.
ORIGINAL: Almighty ODST
i completly agree with you, i had a sensored novak 4500SS then went to sensorless xcelorin 7700, dont notice any clogging. Great idea to check local track for regs. Mamba motors are very popular, you will find much more support than the losi motors. From what i understand, mambas 7700 motors dont support S3 lipo's. so post what your planning on buying on here for suggestions.
This is the motor ESC combo Im thinking about getting.
http://www.losipartshouse.com/servle...l?sfs=d9f3eee8
From reading about it it seems like a pretty good and pretty fast motor for the price. Keep in mind that I want a fast motor but I cant afford to spend over $200 on a motor right now. I still gotta buy some hop ups for my XXX-S and Im thinking about buying an E Savage cuz I want a truck too.
Hi,
I have just gone brushless with an Mtroniks Gensis controller. I dont race but bash hard, this ESC is waterproof and is ideal for my needs.
Check out Mtronics.net.
There is no programming software and adjustment is limited compared to the Castle Mamba Max, but hey you cant have everything !
Good luck
Martin
Good luck
Martin
