trackion problems with the 4-tec
i have a problem with my nitro 4-tec 2.5 when i take off with it it goes fine in a straight line but when i try to turn a high speed it whips a 360 it pisses me off i got some new pro line road rage tires for it but my tires are glued to the rims so i cant put them on what the hell should i do
well....v-rages are decent tires that should handle pretty well. how fast are you going when you turn and it goes off into 360's? if your in second gear you can't expect it to turn sharply without spinning out. also, if you are running on a "rough" street the road rages would be a tad better but i don't think that would fix your problem completely. if you have time you can pry the tires off the rims and put the new tires on, but trust me its tough and will take a while. good luck
