T-maxx 2.5 Running Problems
OR
My engine will fire up and run, but, Sometimes it will feel good and strong, then it will run laggy. Its the Stock 2.5.
For example:
I fire it up, First 30 seconds of run time will be good and strong like its supposed to be...then it will act like its lagging. But, what gets me, during the same run time, it will jump back and forth between the 2.
It also has a problem Idling, it will just stall out sometimes...about 50% of the time I'm just sitting still with it, it dies.
I am thinking its an Air Leak, But would like to find out if it could be anything else from More experianced RCers.
For example:
RE: T-maxx 2.5 Running Problems
Possibly dirt/obstruction in the carb/fuel system (would explain intermittent fuel supply/fuel starvation).
An air leak would be more consistent?
you might have the same problem i had. You should turn the high speed needle all the way back and set it to factory specs(should be in the manual). From there on just tune it a little more untill you like it.
OR
Anyone have the factory Specs for the HSN? Bought this used, rebuilt the engine and dont have a Manual.
Thanks everyone for their Input, I'll give it a try Sunay and see how it works
ORIGINAL: sch1tz0fr3nik
Also, any time I rebuild a motor I always rebuild the carb.
http://www3.towerhobbies.com/cgi-bin...?&I=LXDGB6&P=7
Good luck. [sm=thumbup.gif]
