Will this Li-Po work in the DX3?
VA
I have a DX3 and want to use Li-Po. I have this Li-Po for my vendetta. Will it work?
http://www.dealextreme.com/details.dx/sku.12821
Justin
P.S. Just to clarify I want this powering the DX3 transmitter and yes I know I will have to mod the actual transmitter I just want to know if this would be able to power it and last long...
Justin
RE: Will this Li-Po work with the DX3?
The battery you use to power the truck doesn't really matter as long as your ESC has a BEC. Most receivers need 6v to operate - the BEC will take any voltage from the battery and reduce it to 6v.
VA
ORIGINAL: ozium
Sorry - edited my post while you were replying.
The DX3 uses 8 AA batteries? At 1.5 volts each that's 12v, so I guess the 11.1v should be enough to power it. You might have a constant low battery alarm happening though.
How are you going to mount it?
VA
ORIGINAL: ozium
Also the one I posted wasn't exactly right here is the right one:
