Tamiya M-03 Wheels
Tamiya M-03 Wheels
does anyone know where i can find mesh type wheels for the tamiya m-03 chassis? i've tried my local hobby shops with no luck.
btw...i'm trying to replicate my mini. for a reference of the actual wheels, click the link below:
http://www.vtecminis.com/gallery/thumbnails.php?album=3
thanks!
thanks!
IL
RE: Tamiya M-03 Wheels
ORIGINAL: boister77
thanks!
thanks!
Either that or paint these.
http://www.rcmart.com/catalog/produc...0-7Spoke-Wheel
I've been having a heck of a time trying to find Tamiya wheels myself. Let me know if you find any good sources. Their site sucks...I imagine they have lots of info on the Japanese version of the site...but they do not include any details...even sizing...for their wheels on their site in English. I finally figured out that HPI's will fit the hex on my Tamiya...just don't know about the widht/height/etc. If you run into any good sizing info or a chart of some sort let me know. If I run into your wheels in my search I'll let you know.
IL
ORIGINAL: Southern Cross
ORIGINAL: The Mad Modder
I don't suppose that you'd be willing to put full size 1/10 sedan wheels on it? They work good if you trim the fender a bit.
on my way home from work, i stopped by another hobby shop. they have these wheels which are almost spot on. they are yokomo tw-131ms:
i even saw some low profile tires that resemble the actual tread pattern on my tires. they are the hpi 4540 v-groove tires:
however, i'm liking the ones from rcmart since they will retian full functionality. good find!
i intend to build a M-03S mini, and wanna put som foam tires on that FWD...what are your opinion on that?...26mm or 32mm? what type of?
IL
ORIGINAL: trf
I think I will go with 26 on the front...but I like the look of the "fat" ones on back, so I think 32 will look more aggresive......but not managed to find anywhere?...on tower or some dinball/stella ?
IL
ORIGINAL: trf
anyone familiar with this wheel:
[link=http://cgi.ebay.com/Wheels-tyres-4-Tamiya-Mini-M01-M02-M03-M04-or-HPI-B_W0QQitemZ250259933786QQihZ015QQcategoryZ111888QQ ssPageNameZWDVWQQrdZ1QQcmdZViewItem]http://cgi.ebay.com/Wheels-tyres-4-Tamiya-Mini-M01-M02-M03-M04-or-HPI-B_W0QQitemZ250259933786[/link]
this looks like it will fit the bill and retain full functionality. all that i have to do is paint the blue.
IL
ORIGINAL: boister77
What brand were you looking at?
IL
These are the only ones I could find that would fit it(you might need to trim the fenders a hair).
http://www3.towerhobbies.com/cgi-bin...?&I=LXNXY4&P=7
All of the foams that have the small wheels in front and large ones in back are made for pan cars and will not work with the m03.
Thanks...
looking and browsing I found some specs near the 26/32 mm width specs, it's like that:
35, 37 and 40 Shore with 26mm width (front tires) and 30mm width (rear tires) available. What that shore represint ???
Thanks...
Thanks...
IL
I believe that shore refers to the hardness of the foam tire. I found this on sportwerks' web site, it should help you understand foams better.
"There are three different firmnesses (called shore ratings) of foam tires available for the Recoil. These tires are ranked by their shore rating and have an associated color code. The softest tires are the 35-shore Pink compound, followed by the 40-shore Magenta, and 45-shore Purple compound which is the firmest. The softer the tire is, the better it will grip the racing surface. This is a double-edged sword though as a softer tire will also wear faster. The 40-shore Magenta is a very good all-around tire, but you can tune your chassis quite a bit by playing with tire compounds. If you’re looking to take away front bite, try the 45-shore Purple compound tires. If you’re looking for more rear grip, the 35-shore Pinks might be the hot ticket on the rear of your car. Don’t be afraid to experiment."
for now, since it will only be used for show, i got some yokomo wheels. they are pretty close to my actual wheels, just the wrong size for the m03 .
anyhow...here's some pics of the progress:
here's the shell. it's still missing the decals.
i used the tamiya smoke spray to create a tint effect on the windows and visor.
i masked the headlights so i can add some leds later. i also masked/sprayed transparent white on the marker lights so it will look more realistic; leds will also be added.
temporarily attached the grill
on the chassis
unfortunately, this chassis is not common with most 1/10th scale models. therefore, it's hard to find matching wheels. for now, i'm using yokomo wheels. this will be used for show. when i drive it, i'll have to switch to the other set.
i also masked/painted the rear tail lights as i plan to install leds
more shots...
and of course...the actual mini
on the chassis
more shots...
