JetCat P80 JR8103 setup ???
My Feedback: (540)
I have a P-80 4.0 ECU and a JR 8103 radio Jetcat manual call for 3 position switch on TX .
My JR 8103 does not have this, would it be possible to use the rotary ( detented) knob on aux3 ??
Or would the ECU get lost when in actual operation as I turn the AUX 3 knob from off-to-Start-stby-to-Auto shutdown?
just how close would the "learned signal" in ECU setup to actual recieved signal must i be???
I care not to have an erroneous auto shut down or off signal while in flight:spinnyeye
My Feedback: (24)
WI
JetCat Setup
When I used to use the Throttle/Aux two lead setup, I routinely used the rotary Aux 4 on the 10X. No chance of bumping it and shutting down unexpectedly.
Full CCW=shutdown without cooldown
Center(12:00 o'clock)=run
Full CW=shutdown with cooldown.
Just follow the Learn R/C menu.
Tom
Tom
NY
It works
To answer your question, yes you can use the rotary for the 3 position switch. I have the same setup and it works fine. Set it up at 12 oclock 3 oclock and 6 oclock positions.
My Feedback: (540)
Re: It works
