ESC Problem/Question
PA
A few months ago, I purchased an electric 4CH P-51D Mustang. After I assembled it I decided to try it out. After turning it on, the motor didn't function. A few seconds later, smoke started coming from the plane. After disconnecting the battery, I inspected the plane and discovered that the wires leading to the power switch and ESC were burned. Will I need to replace the ESC or can I just replace the burnt wires? Feel free to ask any questions about the plane. Any help will be greatly appreciated.
Thanks in advance,
plane phanatic
Thanks in advance,
plane phanatic
RE: ESC Problem/Question
You could just replace the wires but that probably will not solve your problem. The switch could be the problem but chances are your ESC is probably at fault. You should also check to make sure that the wiring connections are correct. ie. batt pos to switch pos to ESC pos. etc...best of luck.
NC
The wires were trying to act like a fuse but didn't "blow" like a fuse would. And like a fuse if you just replace it it will more than likely just blow again. You need to discover what caused the fuse to blow in the first place and the ESC is a prime candidate.
