Sanwa Gemini II question
Hi all,
I did a search and can not find the same question nor the answer. When setting the EPA for steering, when i mvoe the stick left L comes up. Move it right and R comes up.
When doing the throttle, it says H. Pushing up or down it stays the same. Unfortunatly i dont have the manual and on my search it seems there no instructions on the net as theres a few people been asking already.
Another Q, on the throttle/brake stick theres only a small amount of travel on down, is it supposed to be like this or has the previous owner set it to it, i have read you can set the tension via removing the back panel. But not the travel.
Thanks in advance!
Thanks in advance!
