Go Back  RCU Forums > RC Airplanes > Twin & Multi Engine RC Aircraft
ScaleTech 80" Bronco ARF, E-powered
Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Old 06-25-2008, 12:50 PM
aeroscale
Default ScaleTech 80" Bronco ARF, E-powered
For those of you considering electric-power in large twins, here's a video of my 80" OV-10, 19 lbs.
http://www.rcuvideos.com/item/MVF08MG7628G8T6N
I've got a 107" version underway....................
AEROSCALE
Old 06-25-2008, 01:44 PM
fancman
Default RE: ScaleTech 80" Bronco ARF, E-powered
WOW! Very nice. Will it be an ARF from Scale Tech?
Old 06-25-2008, 02:52 PM
v22
My Feedback: (8)
very impressive ,,, looking forward to kits .
Old 06-25-2008, 03:38 PM
SunShyne
My Feedback: (68)
SunShyne's Avatar
im confused, your pic shows it to be a built up kit but your thread states and ARF? is it destined for ARF'ness or a kit?
Old 06-25-2008, 03:54 PM
aeroscale
Let me clear this up. The PHOTO is of my new project, a 107", electric-powered Bronco. The video link is to show the ScaleTech (Hobby Hangar) 80" Bronco ARF powered by electrics rather than glow. That ARF has been available for quite some time. I have NO plans, at the moment, to make the 107" version available in anything other than plans form. Sorry for the confusion, hope this straightens things out.
Here's a link to the 107" version, gas-powered (G-38's). http://www.rcuvideos.com/item/QQWFCJY1SQ19SHXK
AEROSCALE.
Old 06-28-2008, 04:39 PM
dmyers0403
My Feedback: (48)
Where did you mount the batteries and the ESC I am curious what the wire lenghts were between motor & controller (ESC) and wire lenghth between battery and ESC
Old 06-28-2008, 05:47 PM
aeroscale
The batteries and ESC's are mounted in the fuselage, just below the cockpit floor. The long wires are between the ESC's and the motors. The battery/ESC location can be seen in the intro to the flight video.
AEROSCALE
ID:	980294   Click image for larger version
Old 06-28-2008, 05:59 PM
v22
My Feedback: (8)
Now I can see that you have no problems with this setup,,but I have been told by CC that you can only have 12 " between the ESC and motors .... but you can have upto 24 " between the batteries and the ESC and in the case of my electric V-22 Joe told me that if I put in some bigger resistors between the power leads to the ESC that I could run those up to the 36 " that I needed to reach the wing tip nacelles .
I guess then it must depend on the ESC's and motors used .!!!????
Old 06-28-2008, 06:23 PM
aeroscale
All of my twin electric models, with the exception of my BH OV-1 Mohawk, have the longer leads running from the ESC to the motors. I've had no problems with any of the models equipped this way. I'm not challenging what you've been told, only telling what has worked, problem-free, for me in my Broncos, Cessna 310, S-3 Viking and Britten-Norman Defender.
AEROSCALE
Old 06-28-2008, 06:33 PM
v22
My Feedback: (8)
Maybe I missed it ,,but what ESC's do you use ??
This could be a company thing with CC only ??? . I am using phoenix 60's in the V -22 and have not talked to any other company about this .
Old 06-29-2008, 12:22 AM
dmyers0403
My Feedback: (48)
How long of wire are we talking about from the ESC to motor?? I have a large scale four engine Lancaster (132"WS) ready to go but read the recent article in the AMA mag about this issue. Seems like the length of wire between ESC and battery is very critical (and short) but long leads between motor and ESC can be tolerated better. Other threads at Rcgroups indicated limits to even the motor leads, +/- 12" to 20" - especially response by CC had sever limits.
I had my ESC at the motor in each nacell, but now must re-engineer this thing question is if I put the ESC (4) into main fusilage I will have about 44" leads +/- to outer nacell motors - trying to figure out if this is a problem - I am also "strongly" reconsidering modifing all motor mount areas at each nacell to allow placement of battery & ESC next to each motor -but only if leads are a problem due to amount of work-redo involved.
Lot of investment here - sooo input is appreciated - Thank for all input so far guys
PS: I also have the 80" Bronco I will convert from glow fuel to electric later.
Old 06-30-2008, 06:29 PM
Low Show
My Feedback: (10)
I'm running at least 22" leads with no problem on my KMP OV-10. The Batteries, leads and ESCs are all barely warm after a 8 to 10 minute flight. The batteries are in the center pod and the ESCs are in each boom. this Pony flys very nice on two E-Flight Power 110s turning APC 17/10s, CCPh.85 HVs, powered by 4 Enerland 4s 5000 mah. These shots were taken by Greg Gimlick at this years Nall.
ID:	981594   Click image for larger version
ID:	981595   Click image for larger version
Old 06-30-2008, 07:47 PM
v22
My Feedback: (8)
O.K. , now I am confused ,, this bird uses CC ,,but you have the ESC's in the booms and probably with the original wire leads to the motor(which would give you about ( " total wire ) . and the leads from the batteries to ESC under the 24 " mark ..so in fact you are within CC's specs ...
You first stated that the battery leads were short and the long leads were from the ESCs to the motors except in your BH OV-1 Mohawk ??
Was that a mis type ??? Just trying to get facts from someone else besides CC or any other manufacture ,,so as not to make a mistake on a lot of money invested .
Thanks for the help
Larry
Old 07-01-2008, 05:10 AM
aeroscale
Hey v22, over here! On my 80" ScaleTech Bronco, the batteries are co-located with the ESC's in the fuselage (center body) and the wires going TO the motors go from that point, out through the wing to the nacelles, to the motors. They are approx. 24" in length, per side.
AEROSCALE
Old 07-01-2008, 05:40 AM
v22
My Feedback: (8)
O.K. I think I see the problem now ,,, it is you have to many OV -10 bronco's for me to keep up with
Old 07-01-2008, 08:03 AM
fancman
In case you didn't know, Aeroscale is the designer of this Bronco.
Old 07-01-2008, 07:20 PM
dmyers0403
My Feedback: (48)
Back to your 107" Bronco Will Canopy and cowls be available with your plans?? Can the canopy be purchased seperate I may need a replacement for my current KMP (I will rebuild the cocpit base etc. Also interested in complete future project.
Old 07-02-2008, 06:00 AM
aeroscale
At this point,I'm not exactly sure of what I'll make available, if anything. This may end up being just a "two-off" project as the canopy is quite large and rather pricey to duplicate. Thanks for the interest, I'll keep you all up to date on the progress of the project.
AEROSCALE
