Can I put a 3.3 in a 2.5 Revo?
Old 06-28-2008, 12:09 AM
beachbrada
My Feedback: (17)
Default Can I put a 3.3 in a 2.5 Revo?
If I can what else do I need to make the conversion or is it a drop in replacement? Also have any of you used the Traxxas engine replacement program?
Old 06-28-2008, 12:45 AM
ajb1205
ajb1205's Avatar
Default RE: Can I put a 3.3 in a 2.5 Revo?
Yes, it is a direct drop in...you shouldn't need anything (other than maybe gearing it up because it's going to wheelie like there's no tomorrow). A friend has a 2.5 chassis that he just put a 3.3 in and he has geared up and put on the extended rear a-arms to help tame the wheelies a little. If your 2.5 is toast might as well send it in with the motor replacement deal...although...I would check ebay first and see what a new 3.3 is going for.
Old 06-28-2008, 10:53 AM
matts6887
matts6887's Avatar
Indeed, like abj alreeady mentioned, it should be a direct drop in other than needing to possibly change the gearing a bit so it dont wheelie soo much, I mean wheelies can indeed be fun, but if it does it too much it might start to get to be a little much after awhile....
Old 06-28-2008, 11:41 AM
e123
ORIGINAL: matts6887
Wheat gears would you suggest puting in to cut down on the wheelies? I just bought a 3.3 to replace my dead 18tz. It came with 15/36 gearing on the tz. I am putting the 3.3 in this weekend, and figured I might as well make sure the gearing is good while I have everything apart.
Old 06-28-2008, 12:46 PM
Clymer122693
15/38 is the most common gear ratio.
Old 06-28-2008, 12:56 PM
e123
So 15/36 would be more low end?
Old 06-28-2008, 05:51 PM
Motox_3
I think I have the 15/36 i have to put a new spur gear on because my meshing was off and it ate the spur but the 15/36 i seem to get more top speed so it is higher geared
Old 06-28-2008, 06:10 PM
beachbrada
My Feedback: (17)
So where is the spur gear located on the engine or is it in the tranny?
Old 06-28-2008, 08:35 PM
Motox_3
Trans it is the big plastic gear
