Hitec Centering issues?
Hey guys i have a GP 330s Extra and am putting a gas 45cc engine on it. My question is the choice of servo. I was going to put the Hitec 5645mg because of the price and torque, but after seeing the way that it centers my Super Chipmunks rudder have started to reconsider. I am know considering the 985mg because it is coreless. My question is does a coreless motor center better than a cored one?
RE: Hitec Centering issues?
The POT and electronic control board (digitals tend to center better) determine center not the motor type. If it doesn't center well the POT may be dirty or bad. They can be replaced if you have basic electronic skills.
Iron core motors do suffer from an effect known as "cogging". Certain design changes to the motor can limit the effect, but these tend to lower the maximum torque. A motor at rest tends to settle at a point between magnetic poles. What cogging means to the servo designer is that it takes a certain amount of motor current for the motor to climb the hill, and thus for a purely analog servo amplifier, a bit of error is needed before enough currect is generated to offset both cogging and friction.
Coreless motors do not have the cogging effect, so less motor current is need to start movement.
However with digital amplifiers, motor type is less important.
ORIGINAL: HighPlains
