Another...Yellow Twin F-18 build
My Feedback: (31)
Well i got a slow start due to one of my taps breaking off in my stab horn so i started and finished (mostly) the nose gear install. I just finished aeropxying n the stab bulkheads. Hey all you guys that have built it, did you glass the fuse-bulkhead joint as well as hysol/aeropoxy?? This will be a somewhat slow build due to me having to fly for work alot nowadays, but i will try to post as much as possible. Nick
My Feedback: (31)
RE: Another...Yellow Twin F-18 build
Dude, Thomas, those mo-fo's are tighter than crap. I tried to get them around the rims today, and they wouldnt budge. I am sure you have a good fix for this. Did you sand off any of the concrete-hard rubber or what?? Hope all is well in Australia. Fly safe man.
My Feedback: (13)
Nice job Nikki! Ahhh NICK We need to hook up sometime man. Let the kids play. Wifes talk and US fly or drink some...[sm=bananahead.gif]
Later man.
Later man.
My Feedback: (23)
Nick,
yea the rubber compound ended up getting harder than what they told me along w/ them "shrinking" slightly more then what i was told to expect as well.. but the plus size is, they will never wear out and they wont ever slip on the rim.
To get the fit a lil bit better, I believe a paper towel or bathroom tissue roll w/ a wrap of 60 grit sandpaper will lossen them up a bit. you can also try soaking them in hot water to get them to expand a bit as well.
My Feedback: (31)
Ok, i have been working on the fins the last few times out in the shop. I got 1.5 of the 2 fins done, hinged, glued and shaped. The hinge covers are all thats left on this fin. It isnt a HARD build, but a tidious one. Heres some pix. I am hoping to get alot accomplished this week, as i will be in and out of work, solots of spare time. Nick
My Feedback: (31)
Ok, so i got the intakes to shape,sanded and installed and the glue is curing. The wings i started on the spar filler blocks, those are shaped and the spars i am starting to shape the last 2 inches of the front. These are a P.I.T.A TO grind down, any ideas besides the obvious=dremel? This week was supposed to be my full out work week on the bug, but the scheduler felt the need to schedule me for Simulators yesterday and today!!![:@] kinda messes up the work time alotted[:@]
Behing the Bug is the wifeys b-day gift to me, a BV Ultra viper kit. This thing is like 12 years old but in awesome shape, better than alot of the glass work out there today. Nick
Hi,
Nick, next time use a band saw like the $90 Ryobi one I bought from Home Depot. They sell a $6 metal-cutting blade that works great for wood, too, so I use it for everything. I drew lines on the spars and cut them with the bandsaw. It probably took 20 seconds per cut, so I was done with all four spars in less than 5 minutes. That metal blade goes through that aluminum like a hot knife through butter.....
My Feedback: (31)
Well got a little bit done since last post. I finished up the wings mounting, all they need is the cap on the end, and then controls. I think i have decided to go with the scale flap hinges. Anybody know of any snags or problems with this??
Today i started the main gear formers installation. The funny thing is that when you mount the left and right forwrd supports and th left and right gear mounts, the right is way different in angle. The even weirder part is that they match up with the jigs. So i called charles and he said this is normal, and "at the end of the day" the gear willbe right.....fingers crossed. You can see what i am talking about in the pictures. Hysol to come tomorrow.
Lastly, this is the scheme i have finalized on. Nick
NJ
Nick,
I too had issues with the L and R gear supports......and I recieved the same answer from Charles, and pressed the "I believe" button and installed them.
It DOES work out in the end......trust him.
Scale flap hinges was something I wanted to do (on my build that hasn't progressed in 6 months...lol), but the rear main spar gets in teh way of the scale hinges.
I didnt feel comfortable with how I would have had to trim the hinges to clear the spar, so I went with conventional Robart hinges.
I know that the scale flap hinges have been done on the ARF version of the bird, but they didn't give me a warm and fuzzy.
Great job on your build, and it has been helping me to get motivated to dust mine off and continue.
Best!
Jeff
Best!
Jeff
