How to find Speed?
Old 07-21-2008, 03:34 PM
TRXRUSTLER
My Feedback: (7)
TRXRUSTLER's Avatar
Default How to find Speed?
I was wondering how fast my Rustler went, but I don't have a radar gun so I don't know any other way to find out...................Thanks.
Old 07-21-2008, 03:45 PM
guver
My Feedback: (325)
Default RE: How to find Speed?
You can time it (distance/time) or maybe plug you numbers into here http://www.scriptasylum.com/rc_speed/_top_speed.html
OR post your specs and someone can guess really close.
Old 07-21-2008, 05:43 PM
elf232
elf232's Avatar
Just set up a 40 yard run on a parking lot and do the math.
Old 07-21-2008, 06:34 PM
TheIronMaiden
some gps units can measure speed, if you have one of those you could strap it to your car and see how fast it goes.
Old 07-21-2008, 06:59 PM
sloppyG
distance/time= speed
just make sure to get your units correct
Old 07-25-2008, 01:53 PM
nissanlove
is it inches/seconds?
Old 07-25-2008, 02:29 PM
calvino
calvino's Avatar
ORIGINAL: nissanlove
that would work to
Old 07-25-2008, 03:21 PM
dsales
dsales's Avatar
ORIGINAL: calvino
that would work to
are you sure about that?
The official units are:
Speed = m/s (metres/second)
Distace = m (metres)
Time = s (seconds)
ahh, it was the 1st thing i learned in physics...
Old 07-25-2008, 11:22 PM
SAVAGEJIM
SAVAGEJIM's Avatar
ORIGINAL: dsales
ORIGINAL: calvino
that would work to
Time = s (seconds)
In the US, we use the British Imperial system (feet, seconds, pound mass). Funny, we dont call it the British Imperial system, we now wrongly call it the "Standard" or "American Standard" system, even though the foot was actually based off of old England's King Henry the 1st (or at least the legend goes). So, it is very funny that the British now use the Napoleonic SI instead of their own British Imperial system. Again, more historical irony, King Lewis (Louis en Francias ) the 16th who made metric system the standard French measurement was killed. The French Republic kept the system, and due to Napoleon's influence, the metric system became the SI and was sperad all over Europe.
Personally, I prefer to calculate most things in SI, speed, as in this discussion, becomes very easy to convert from Km/hr from m/s and so forth. I can even do it mentally without the aid of a pencil & paper. In the British Imperial system, it is much harder, converting from ft/s to mi/hr is much harder. There are 12 stupid inches in a foot (Why cannot it be TEN inches per foot?). King Henry ole #1 should have had his foot cut off by the toes! Then, feet would be much more easier to work with because there would be 10inches to a Henry foot! Worse, there are 5280 surveyed feet in a statute mile! They should have made a concept of a kilo foot, or at least a kilo yard. That way converting from ft/s to mi/hr would be much easier.
Sorry for the rant, this is my beef with the British Imperial system when calculating speeds. I like to do things mentally, but because of the Brit Imp system not being divisible by ten, I have to resort to a calculator, spreadsheet, etc when converting ft/s to mi/hr (or even yd/s to mi/hr)
Old 07-25-2008, 11:23 PM
JATO TO THE MAXX
Or you could just buy the Venom Speed Meter
[link]http://www.venom-group.com/itemdesc.asp?ic=VEN%2D0615[/link]
Old 07-26-2008, 02:34 AM
Gex_61
Gex_61's Avatar
Do it without ever turning your car on.
http://www.teamassociated.com/racerh...ripttable.html
http://www.teamassociated.com/racerh.../gearform.html
Old 07-26-2008, 03:40 PM
SAVAGEJIM
SAVAGEJIM's Avatar
ORIGINAL: JATO TO THE MAXX
I have one of those, I used it on my R40. Nifty gadget to see how fast a car goes on a straight, but it unfortunately only adds unwanted weight on the track.
My only problems I have with this Speedo is getting the oll-out corect. Then, as the foam on the tires wear down, doing another roll-out to account for the reduced wheel's diameter.
Old 07-26-2008, 03:44 PM
SAVAGEJIM
SAVAGEJIM's Avatar
Those are very nifty, and I use those very same formulae on an Excel spreadsheet. The only problem with that is the part of the RPM. You really dont know if your car will turn those RPMs unless you actually do some field testing. For example, an engine is advertised to reach 42000RPM (and virtually all RC advertisers are lying snakes). Put high gears on the engine and run that car on the street, wnd you will discover very quickly that the engine simply does not have the torque @ 42000RPM to turn those gears. The engine might reach 35000RP max on those high gears, so the calculated speed at 42000RPM on high gears is moot.
Old 07-26-2008, 05:29 PM
sloppyG
it's whatever you want
you have to convert from whatever distance you time (say 50-100 feet) to miles, and convert the time into hours
you'll get something like (random here) 30 feet/second, figure out how many feet/hour, then convert the feet to miles/hour
