ax10 axles
08-03-2008, 10:33 PM
ax10 axles
ok I just got done putting together my somewhat scsale ax 10 on a xtrail frame.. my problem/question is.. the fron axle is pitched almost 45degrees.. is this normal or should it be flat ? My radius seems to be comprised.. I honestly dont remember what it was like before I took it apart...
08-03-2008, 10:35 PM
ON, CANADA
RE: ax10 axles
The knuckle turns on screws, those screws should be pointing more or less straight up and down.
08-03-2008, 10:37 PM
ON, CANADA
RE: ax10 axles
You can adjust it by changing your link lengths and/or positions.
08-03-2008, 10:39 PM
RE: ax10 axles
so if I am pitched up almost 45degrees and lenghten my lower arms it should bring the pitch down right ?
08-03-2008, 10:40 PM
MI
RE: ax10 axles
or shorten your uppers!!
08-03-2008, 10:41 PM
RE: ax10 axles
ok, I am still all new to this Thank you for the help.. do you use aim or yahoo.
