Servo reversing?
Servo reversing?
I was told that you can swap the red and black wires on a digital servo to reverse it, is that correct? I am used to switching the two wires on the pot and two on the motor to reverse them.
I need them for flaps and would rater not use a extra channel or reversing harnesses etc.
RE: Servo reversing?
Many years ago that was the only thing you could do, switch the wires. Nowadays it can be done in TX. Of course if your TX don't allow that then try switching. If you are using digital servos I would assume you have current radio equip.
ORIGINAL: Pegasus
No, you also have to swap the 2 outer wires on the feedback pot/resistor as well. Leave the middle wire alone.
A while back I thought I could reverse a servo (Futaba 9001) and I ended up killing the motor. I found I needed to buy a servo reversing 'Y' harness.
BTW, I switched the 2 leads, not the leads to the motor itself.
My Feedback: (23)
ORIGINAL: digitech
how you program it?
ORIGINAL: DelGatoGrande
get 5955 for 89usd and program it
how you program it?
http://www.chiefaircraft.com/rcmsec/...rogrammer.html
http://www.flying### giants.com/forums/fg29/15606-jr-matchbox-hitec-programmer.html
ORIGINAL: Pegasus
ORIGINAL: Steve Collins
Isn't it possible to simply orient the flap servos so that the top of the servos are facing the same direction (assuming of course that the servos are laying flat in the wings)?
yes
boomerang jets and some fei bao jets have this set like you mention
brilliant and simple.
just need a V cable
ORIGINAL: digitech
yes
just need a V cable
yes
just need a V cable
Hitec digitals + programmer = no matchboxes, no Y harnesses, no frozen chickens.
ORIGINAL: causeitflies
Don't you mean a "T" cable?
ORIGINAL: digitech
yes
just need a V cable
yes
just need a V cable
Can not speak for digitals, but i reverse analog servos all the time.
Switch the 2 wires to to the motor and switch the 2 outside wires on the pot.
Works perfectly.
Paul
Works perfectly.
Paul
