help!! need to nkow how to get a-arm back on
ME
well, i when to my local off road track today...and i was getting good an im going to race this sunday....im not as good as most that race there but if i dont try i never will be well anyway...i had an off landing when i started showing off and jumping as far as i could...how do i fix this?
UT
RE: help!! need to nkow how to get a-arm back on
The ball on the end of the A-arm will unscrew with an allen wrench. Then you haft to take off the wheel to unscrew the….cap…thingy off the bottom of the weal hub. Then just put the ball back in and screw it into the A-arm.
But you might need to replace the hub that the A-arms connect to if they come out like that on a crash….on my t-maxx I think the A-arms would break before the balls would pop off like that. The part might just be really warn out.
(my parts terminology might be a bit off, so if anyone wants to correct me feel free)
see the Pick
see the Pick
when you screw that ball back into the a-arm make sure only to tighten it until you cant see the threads any longer. do not tighten it any more then that or you front end will become to stiff. same thing when you put that round plastic piece back onto the axil carrier.. do not over tighten that either.. jake
