Setting Up A CP Brushless Hornet With A CSM HLG200 Gyro
Do you guys set it up with the standard 30mm tail pitch at neutral, or do you go with less pitch. ATVs don't work with the CSM like they do with my PG03, so the CSM wants to put out too much throw and I get binding if I start with 30mm at neutral. Thanks.
