Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
450 V2 running hot, surging...
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 08-30-2008, 11:00 AM
zaboaa
Default 450 V2 running hot, surging...
Crashed my 450 about 3 weeks ago and rebuilt it. Now when I run it, the engine and speed controller get blazing hot, and eventually quits. It is also surging big time. The main gear is not to tight and there doesn't seem to be any binding (in fact I've always run my rotor belt on the loose side, as it is now). The engine has about 200+ flights, do you think it might be going bad? The speed control is fairly new so I do not think that is the problem. Any help appreciated.
Mark
Forgot to mention that it also sometimes makes a loud whinning noise....
Old 08-30-2008, 12:02 PM
qwerty3
Default RE: 450 V2 running hot, surging...
I can't say from experience, since I'm just now buying a T-wrecks , but is it possible the pinion is loose on the motor shaft? Seems like it might be related - ?
Old 08-30-2008, 01:36 PM
zaboaa
ORIGINAL: qwerty3
No, I actually replaced the pinion all together and have readjusted it several times. Same result. Thanks for the help though.....
Old 08-31-2008, 04:48 PM
Missileman
Missileman's Avatar
I was going to say the same thing, pinion gear slipping on the motor shaft. Same thing happened to me with exactly the same results but you said it is tight so the only other thing I can think of is maybe a slipping one way bearing?
