Trex 600 tail spin problem
I am using gy401 with dig servo. The heli will lift off somewhat smooth, but as i increase throttle it wants to spin then if I decrease throttle it spins the other way. Is this from the direction switch being reversed on servo??? thanks for any help.
RE: Trex 600 tail spin problem
No REVO on, all are 0%, I even tried to switch gyro direction to see if it was backwards, but that was not it. I can hover ok, but as soon as i yaw left or right the heli goes up or down with that movement. I copied all the settings from my other 600, so it has to be something with gyro or wiring... dont know....
ok, done and done, light is contiuously on now, unless it move rudder. but it still loses altitude when turning tail. Could the gyro be bad??? thanks
