BobCat Antenna HELP
BobCat Antenna HELP
Old 05-25-2003, 12:00 AM
Cooper
Default BobCat Antenna HELP
Hi Guys
Just how did you manange to get the antenna wire inserted through the interior bulkhead and all the way into the nyrod ?
Thanks!
Old 05-25-2003, 12:23 AM
Scott Ramberg
My Feedback: (15)
Default ff
Line up with blue nyrod and drill a hole through the bulkhead. Insert the nyrod. Spray a little Pledge on the antenna and feed it through. Piece of cake!
Good Luck
Scott
Old 05-25-2003, 03:13 PM
Gordon Mc
WD40 works as well - that's what I used to lube the inside of the nyrod.
Old 05-25-2003, 04:47 PM
DavidR
Or buy a piece of the clear dubro antenae rod material and use that instead of the yellow nyrod stuff. Much easier to shove the antenae wire into.
Old 05-25-2003, 07:40 PM
Cooper
Thanks guys for the suggestions. I wound up usings a "pull cord" of solid 18 awg wire to pull the antenna wire through. Tried the WD40 and the Pledge and didn't have the nylon tube available. I think the 90 degree heat here made the antenna lead too flexible to push through. Appreciate all the suggestions.
BRG
Cooper
