Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Monster Trucks > Traxxas Monster Truck forum
How to convert your Traxxas Slayer pro 3.3 nitro truck with a reverse.
Old 10-23-2008, 02:30 PM
nitroheli
My Feedback: (33)
Default How to convert your Traxxas Slayer pro 3.3 nitro truck with a reverse.
How to convert your Traxxas Slayer pro 3.3 nitro truck with a factory reverse.
TRX5396X Primary Gears Frw/Rev
TRX5391X Gearbox Halves Fr/Rr
TRX5389X Shift Fork/shaft T-Maxx
TRX5377 Revo Idler Gear/Sup/Bearing
TRX5397 Revo Optidrive Sensor Assy
TRX3982 Washer Teflon 6x8x5 (10)
TRX5395 Revo Forward/Rev Output
TRX5121 Bearing Needle Rolle (2)
TRX5369 Revo Tran Output Shaft
TRX5324 Revo Right Electronics Box
TRX5398 Revo Optidrive Elec Shift
TRX5325X Revo 3.3 Electronics Box
TRX5392 Revo Shift Linkage
You must also pick up a micro servo for the reverse function. You will also require a 3ch transmitter and receiver.
Download the information from the Revo 3.3 std version installation and parts breakdown PDF file. Use that as reference. www.traxxas.com
Hope this helps and enjoy..
Rob
Old 12-27-2008, 05:21 PM
BEMEROX
BEMEROX's Avatar
Default RE: How to convert your Traxxas Slayer pro 3.3 nitro truck with a reverse.
You need a reverse moduel. I am sellin a savage one
Old 12-27-2008, 09:13 PM
rcnitrohead
rcnitrohead's Avatar
Bemerox- You are a trolling fool
Old 12-29-2008, 10:59 AM
nitroheli
My Feedback: (33)
Use this link for all updated info on the conversion, takes you direct to my forum on Traxxas.
Cheers
Rob
http://monster.traxxas.com/showthread.php?t=442928
Yes the Module is ok for a 2 ch transmitter, but the second you change your trim you have to reset it, Its not always a great system and some times you need to reset it more than one time during a run, This can be bothersome....
Rob
Old 07-21-2009, 01:33 AM
JLAG
Hello Rob. I was surfing looking for options to convert the Slayer to Reverse and I found you in more than one search engine... I hope you can help me: Do you know if the conversion kit from Traxxas for the Revo 5395X has the neccesary parts for making the conversion you did? I cannot find anywhere the detailed parts list of this item, so you may know. I am not interested in installing the Optidreive system, I just want the mechanical switch to reverse. Thank you!
Best regards,
JLAG
Mexico
Old 07-21-2009, 08:33 PM
muttracer_61
not trying to jack your thred but what is the best glow plug for my slayer running 20% nitr 10% oil
Old 07-22-2009, 08:39 AM
larryf333
larryf333's Avatar
Mutt, you did jack his thread. Just stick with the stock plug. If it keeps going out, then your engine is out of tune.
Awesome info Nitroheli. I was wondering when someone would figure out how to put a reverse on the Slayer.
Old 08-31-2009, 10:01 AM
koolaid_89
I checked on the same thing and i think you coud get on ebay and find a revo transmission with optidrive and also find and optidrive unit. I looked at the exploded view on traxxas for the revo and the slayer and the transmission cases are the same number so the optidrive tranny would fit. Ordering the whole tranny would save you the time of tearing down and might be a little cheaper than ordering all the parts to fit yours. Your also gonna need a 3 channel transmitter ought to be able to find a traxxas one on ebay if thats what your using and your traxxas receiver in your slayer would work it is allready a 3 channel just put your transmitter crystal in the one you get. Heres a list of what you would need
Transmission Ebay $45-$65
Optidrive unit Ebay $10
Radio Ebay $30 or if you want 2.4ghz ive seen them for $120
servo box #5325 Tower $5.49
clip #3935 Tower $2.89
micro servo #2060 Tower $25.29
shift linkage #5392 Tower $3.39
screws #2575 Tower $2.39
I think thats all you would need hope that helps....Koolaid
