Rave, Beam or Align V2 tail assembly which one is best?
Hi guys,
Looking to buy a new tail set for my Dragonus 450. (3mm tail shaft)
Just wanted to know which tail gives the best flight performance and has no problems with vibration (part tolerances and quality control).
Rave: http://www.readyheli.com/Rave_450_Ta...d-yr-as008.htm
Beam: http://www.readyheli.com/Beam_E4_Tai.../bmh421420.htm
Align V2: http://www.readyheli.com/HS1257_84_A.../hs1257-84.htm
I'll be using it with K&BDD blades.
Thank you guys.
Thank you guys.
