Ceramic Clunks vs UAT?
Does anyone use these INSTEAD of a UAT? If so does it work better or the same or what? Seems to me that if it works just as good as a felt UAT then the benefits are less weight and potential leaks.
Andy
Link to clunk:
http://www.jetpowerus.com/shop/categ...m=cid%3D110%26
Andy
Link to clunk:
RE: Ceramic Clunks vs UAT?
UAT is certainly the way to go and the people who use a UAT are far less likely to have a fuel related flame out.
If there is one single item that has given reliability to turbine models then it's the UAT.
J
J
ORIGINAL: jason
J
J
A UAT may be better than one of these ceramic thingies, but it is certainly NOT better than the pleated paper filter.
ORIGINAL: Woketman
ORIGINAL: jason
J
J
How interesting,
why do you think that?
Jason
ORIGINAL: jason
How interesting,
Jason
ORIGINAL: Woketman
ORIGINAL: jason
J
J
How interesting,
Jason
ORIGINAL: AndyAndrews
yea , never heard that before.
ORIGINAL: jason
How interesting,
Jason
ORIGINAL: Woketman
ORIGINAL: jason
J
J
How interesting,
Jason
In the drawing below the system in placed in a 2 oz Sullivan tank, and should be let up right for best performance.
Steven
ORIGINAL: S_Ellzey
It has been a few years since this was explained. The filter acts as a fuel tension screen, once it is wet, air can not get through as long as some small portion is still in the fuel. This concept has been used in cruise missiles.
Steven
ORIGINAL: jason
How interesting,
Jason
ORIGINAL: Woketman
ORIGINAL: jason
J
J
How interesting,
Jason
Steven
I think most of us on here know the reasons why and how a UAT works but I am wondering why Woketman thinks a pleated paper filter is more effective than a UAT bearing in mind that the wetted area of the strainer in the UAT is larger than the paper type.
jason
ORIGINAL: seanreit
I would then refer you to the search button where both of them have explained this before in great detail.
The "Search" engine in RC Universe SUCKS and you know it. I hate using it. Half the time you never get any good results and you end up spending wasted time finding something that can be answered rather quickly.
If they updated the search feature this board would probably be half as large.
Plus, he never said it was better than a UAT. He said the UAT was not better than the pleated paper.
The explanation given by S Ellzey was for the pleated paper filter, not the UAT.
My Feedback: (60)
ORIGINAL: seanreit
I will post others for a fee!
http://www.rcuniverse.com/forum/m_16...tm.htm#1689873
My Feedback: (60)
Is this list search result too long for you? AGAIN, TWO SECONDS TO DO THE SEARCH.
http://www.rcuniverse.com/forum/sear...mitbutton=+OK+
ORIGINAL: G4guy
I have flown thousands of flight with Mercurys, Pegasus with nothing but a 4,6 or 8 oz hopper tank with a felt filtered clunk. I have never had a flame out. If it works, I stick with it!
Ron
Ron
I ran the fuel so low that the pump was pulling FOAM out of the UAT and onto the engine. It still ran fine although the pump was working hard.
I was amazed ! [X(] The Merc/Peggy/Olly family are very bubble tolerant.
Other (usually smaller) engines will quit with just one bubble.
ORIGINAL: seanreit
heres what you get with the "ceramic filter" search:
http://www.rcuniverse.com/forum/sear...D&sortMethod=d
I would have to open each and every thread to find what I am looking for. The search engine should pull out any word that says "ceramic" and point you to that post. Unless someone actually puts the word "ceramic" in the title it won't find it directly.
The reasons that I feel that the pleated paper is better than the UAT (and I have used both) are multiple: A) When I use the pleater paper, I mount it in a 20 or 24 oz. (Dubro, I think?) tank on a very thin walled Tygon tube with it weighted. It also then acts as a clunk and if there is an air leak or some other reason that air enters the hopper tank, you have a larger margin because the pleated paper also uses surface tension (as the UAT) but also follows the fuel around. B) its WAY cheaper! C) it allows me to use the 20 or 24 oz capacity of the hopper tank for a bit extra fuel volume D) no hassles of getting rid of bubbles.
That said, there are situations where a UAT is preferrable such as my Boomer Sprint where there really is no convenient spot for a 20 oz tank. I would have then made my own header, such as the MAP one (a small Nalgene bottle with a pleated paper filter in the middle, held rigidly), but I found a UAT laying around (I'm lazy!).
