NEW Product Annoucement: Electric Scimitar Props from CERMARK
Product Name: EMP - NEODYM Electric Scimitar Props
Category: Electric Propellers
CERMARK: www.cermark.com and then search “scimitar”
Sample 13 x 8 Scimitar Prop Page: http://www.cermark.com/products/EMP-...13x8-prop.html
Email: [email protected]
Description: These are new electric scimitar propellers designed specifically to meet the demands from our high performance electric flyers.
First, the wicked scimitar shape of these blades reduces wave drag at high radial velocity. Second, the specially designed upturned “tiplet” minimizes prop tip turbulence. Third, the disc or hub is lightened using multiple designed cavities. Fourth, a complete set of shaft adapters or inserts are provided with every electric scimitar blade. Finally, these aerodynamic blades use improved composite for superior rigidity.
The unusual blade shape gives more power than your conventional electric prop blades. Because they are more efficient, they will provide you with longer flights.
Content: 1 x electric scimitar prop with shaft inserts
Advantages:
1. Efficient aerodynamics
2. Reduced noise
3. High rigidity
4. Greater power
5. Larger selection (4.1” to 30” - 50 sizes)
6. Improved efficiency (input to thrust)
Model # Size (E-Scimitar)
EMP04141ES, 4.1 x 4.1
EMP04545ES, 4.5 x 4.5
EMP04747ES, 4.75 x 4.75
EMP05050ES, 5 x 5
EMP06030ES, 6 x 3
EMP06040ES, 6 x 4
EMP06050ES, 6 x 5
EMP07030ES, 7 x 3
EMP07040ES, 7 x 4
EMP07045ES, 7 x 4.5
EMP07050ES, 7 x 5
EMP07060ES, 7 x 6
EMP08038ES, 8 x 3.8
EMP08040ES, 8 x 4
EMP08050ES, 8 x 5
EMP08060ES, 8 x 6
EMP08070ES, 8 x 7
EMP09038ES, 9 x 3.8
EMP09045ES, 9 x 4.5
EMP09047ES, 9 x 4.7
EMP09060ES, 9 x 6
EMP09075ES, 9 x 7.5
EMP10050ES, 10 x 5
EMP10060ES, 10 x 6
EMP10070ES, 10 x 7
EMP11055ES, 11 x 5.5
EMP11070ES, 11 x 7
EMP11085ES, 11 x 8.5
EMP11010ES, 11 x 10
EMP12060ES, 12 x 6
EMP12080ES, 12 x 8
EMP12010ES, 12 x 10
EMP12012ES, 12 x 12
EMP13080ES, 13 x 8
EMP13010ES, 13 x 10
EMP14070ES, 14 x 7
EMP14080ES, 14 x 8
EMP15080ES, 15 x 8
EMP15010ES, 15 x 10
EMP16010ES, 16 x 10
EMP17080ES, 17 x 8
EMP17010ES, 17 x 10
EMP18080ES, 18 x 8
EMP18010ES, 18 x 10
EMP18012ES, 18 x 12
EMP19010ES, 19 x 10
EMP20012ES, 20 x 12
EMP22012ES, 22 x 12
EMP24012ES, 24 x 12
EMP30020ES, 30 x 20
CERMARK
Tel: 562.906.0808, Fax: 562.906.0820
9830 Bell Ranch Dr, 101, Santa Fe Springs, CA 90670
Email: [email protected] URL: www.cermark.com
All information on this document is proprietary to CERMARK. Usage without written consent from Cermark will be subject to legal prosecution
Advantages:
2. Reduced noise
3. High rigidity
4. Greater power
EMP05050ES, 5 x 5
EMP06030ES, 6 x 3
EMP06040ES, 6 x 4
EMP06050ES, 6 x 5
EMP07030ES, 7 x 3
EMP07040ES, 7 x 4
EMP07045ES, 7 x 4.5
EMP07050ES, 7 x 5
EMP07060ES, 7 x 6
EMP08038ES, 8 x 3.8
EMP08040ES, 8 x 4
EMP08050ES, 8 x 5
EMP08060ES, 8 x 6
EMP08070ES, 8 x 7
EMP09038ES, 9 x 3.8
EMP09045ES, 9 x 4.5
EMP09047ES, 9 x 4.7
EMP09060ES, 9 x 6
EMP09075ES, 9 x 7.5
EMP10050ES, 10 x 5
EMP10060ES, 10 x 6
EMP10070ES, 10 x 7
EMP11070ES, 11 x 7
EMP11010ES, 11 x 10
EMP12060ES, 12 x 6
EMP12080ES, 12 x 8
EMP12010ES, 12 x 10
EMP12012ES, 12 x 12
EMP13080ES, 13 x 8
EMP13010ES, 13 x 10
EMP14070ES, 14 x 7
EMP14080ES, 14 x 8
EMP15080ES, 15 x 8
EMP15010ES, 15 x 10
EMP16010ES, 16 x 10
EMP17080ES, 17 x 8
EMP17010ES, 17 x 10
EMP18080ES, 18 x 8
EMP18010ES, 18 x 10
EMP18012ES, 18 x 12
EMP19010ES, 19 x 10
EMP20012ES, 20 x 12
EMP22012ES, 22 x 12
EMP24012ES, 24 x 12
EMP30020ES, 30 x 20
CERMARK
