need help with transmitter stat!!
I just changed the engine on my buggy, pluged everything back, and now my throttle trigger has reversed itself??
can someone please help[&o]
RE: need help with transmitter stat!!
your radio should have a switch for servo reversing if it is a lower end radio. if its a higher end one with an LCD screen there will be screen for servo reversing.
I'm guessing its an electric buggy and you mean motor? most likely you got it wired backward if you didnt make any changes other than the motor.... Using the servo reverse switch would be a bad idea, since then you would have your brakes only in reverse, not forward...
a little more info generaly helps... what type of buggy? what was the old motor? the new motor? what esc?
