Got Pizazz Rudder Pull-Pull Picture?
Old 05-30-2003, 06:57 AM
ChiefThief
ChiefThief's Avatar
Default Got Pizazz Rudder Pull-Pull Picture?
I'm putting together a Pizazz, and want to use pull-pull on the rudder with the servo mounted as close to the rear as possible. It seems like everyone agrees that is the way to go, particularly with a heavy engine.
Does anyone have any pictures of that setup? I can't tell what area would be strong enough to mount a servo.
I hope to go flying this weekend, and this is the only thing holding me up, so any help would be greatly appreciated.
Old 05-30-2003, 09:49 AM
tinman
My Feedback: (13)
Default .
i put p/p on the rudder and elevator on mine...had to do major surgery behind wing. i removed the covering on bottom behind wing and installed a hatch cover there also. after you remove covering just build a mount for your servo so it is inline and at right height for your rudder. biggest prob i had was routing the wire because there is not much room and seemed like everything got in the way. mine has a ys63 on it and i still have not flown it...work is holding me back
Old 05-30-2003, 02:09 PM
djlyon
No pictures. I used about .035 music wire running inside to nyrod push rod tubes. Installed easy and works well. I do have the servo at the trailing edge of the wing.
