MGT 3.0 PROBLEM
MGT 3.0 PROBLEM
I JUST BOUGHT IT 2 MONTHS AGO AND EVERYTHING WAS FINE UNTIL YESTERDAY.IT GOES BY ITSELF WITHOUT TOUCHING THE THROTLE.I DONT KNOW WHY IS LIKE THAT.PLEASE HELP ME TO FIX THIS PROBLEM ASAP
THANKS
THANKS
Moderator
RE: MGT 3.0 PROBLEM
Check the trim settings on your controller. It may have been altered so that the idle speed is fast enough to engage the clutch. Also make sure your clutch isn't destroyed and adhered to the bell.
RE: MGT 3.0 PROBLEM
If it's gotten significantly colder you are definitely going to have to retune it. If it's way out of tune it could be running lean and revving up causing it to wander.
RE: MGT 3.0 PROBLEM
you know what you are amazing I just pulled everything out and found the problem one of the clutch spring is broken.I will change it tomorrow
Thanks a lot
Thanks a lot
