DL-50 Question
DL-50 Question
I am done breaking in my DL-50 with 32:1 Lawn Boy Ashless, and I'd like to know if i can safely use 80:1 synthetic oil in it. The reason i ask i so i can just stick to one gas can, and use the same mix that i use in my 3W , instead of lugging 2 gas cans around??
RE: DL-50 Question
ORIGINAL: JoeAirPort
DL says you can use Amsoil Saber 100:1 after break in. Just like DA.
RE: DL-50 Question
I havn't used Amsoil but I do use another brand synthetic that mixes at 114:1. If I go much below 80:1 It gets kinda stiff when starting it up after sitting a day or more. The 100:1 mixes probably start with a high viscosity base (mine does) so going much below say 75:1 with 100:1 Amsoil might not be such a good thing. I'm happy and convinced mine gives me piece of mind mixed at 80:1, and there is a slight power increase and crispness to throttle response over mixing at 114:1. These synthetic companies are in a contest to have the oil that protects at the highest ratio possible, a bit more oil can't hurt. And just in case the company is full of b.s. you are protected.
MI
RE: DL-50 Question
I agree. I like 20:1 on two cycles. I used to run Castrol two cycle oil in a Kawasaki 500 and when I'd pull the cylinder head I could wipe out the carbon residue with lacquer thinner and a paper towell back to bare aluminum. I'm sure the oil injection system was delivering much less than a 20:1 mix though.
Bill
Bill
RE: DL-50 Question
ORIGINAL: flatspinjim
I would go with the bacon grease. It smells great first thing in the morning!
i agree
i'll start using 80:1 (amsoil) in my DL50 then, thanks for the input, now i wont have to mess 2 gas cans now
RE: DL-50 Question
Shoot, might even add a shot of Jim Beam for a little extra kick!
My Feedback: (41)
RE: DL-50 Question
I believe I was thinking of the Area 51. That engine's instructions say Amsoil 100:1 after break in.
My Feedback: (41)
RE: DL-50 Question
ORIGINAL: outssider
yeah but it also says he mixes 3.5 oz to two gallons of gas which is 73.143 to one (i think he failed high school math)
And you're right it's 3 oz of oil to 2 gallons for an 85:1 mixture: 128/85 = 1.5oz per gallon, or 3oz per 2 gallons.
http://www.dlusa.net/FAQ.html
RE: DL-50 Question
ORIGINAL: telejojo
Does anybody have a mounting template drawing? or what page irs on
http://www.dlenginesaustralia.com/do...lltemplate.pdf
