Momentary Push Button on 12X
Old 12-10-2008, 11:33 AM
John Redman
My Feedback: (8)
Default Momentary Push Button on 12X
We have recently had a numebr fo request to change out the flight mode switch on the 12X to a momentary push button as was on the 10X. For some odd reason there are people telling owners of the radio this can be done. These people have no affiliation with Horizon Hobby or JR radios. I can assure all of you this is not possible. The software will not allow the change.
We do have a software upgrade which will make the trigger switches at the corner's of the gimbles work as an on/off button with just one click. No longer do you need to hold it one way or the other for operation. This software upgrade allows the trigger switches to be used either way as you choose.
For those of you who lived on this button for smoke, I understand your frustration. Hopefully this software upgrade will help out.
One other note for 12X owners. Please do not open the case of hte radio to check something out or such. If when opening the radio you do not follow a very prescribed program you will damage some of hte PC boards which pulls the traces off the boards. The end result is close to a $300 repair bill to fix the radio.
Take care,
Old 12-10-2008, 11:46 AM
RCI/Skymaster
Banned
Default RE: Momentary Push Button on 12X
Thanks for the intel John.
What is the turn around time for the update?
Old 12-10-2008, 12:13 PM
GSR
My Feedback: (145)
John , Sent you a PM about this., THe best JR rep out there has a fix.
Old 12-10-2008, 12:24 PM
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
gents
i've got my old trusty 10x in the shop at the moment and the boys are looking at about a 10 bidness day turn around.
Old 12-10-2008, 01:05 PM
John Redman
My Feedback: (8)
Weather or not you need the update will depend on how old your 12X is. Turn around time is very quick. Buck, it is time for you to upgrade!!!!
Old 12-10-2008, 01:10 PM
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
soon grass hopppa soon
Old 12-10-2008, 02:31 PM
BlackCloud
My Feedback: (12)
BlackCloud's Avatar
Sending mine in!
Old 12-14-2008, 05:51 PM
tclaridge
tclaridge's Avatar
John,
I do not know if I need the push button feature, but maybe you can help me out or point to someone that can. How can I start the count-down timer when I throw the throttle-hold switch? I would love to do this on my electrics. Can I do this with some programming?
PS I flew the Beaver on floats at a charity event and it was a big hit. The slow fly-by with full flaps, low over the water was a crowd pleaser. I am awaiting your next Platinum Series warbird! (My vote is a flap/retract Hurricane or F-86 in 25 size).
Old 12-14-2008, 06:11 PM
SinCityJets
Tclaridge,
I don't know how to activate it with the throttle hold, but I can help you activate it with throttle position if that will help?? I set it up for my turbines that when I go to full throttle, it activates the timer.
Old 12-14-2008, 06:27 PM
tclaridge
tclaridge's Avatar
SinCity, I know how to activate with the throttle stick, but when I go to idle, it stops the count down. I do not want this, as I want to time the flight and not the throttle-on time.
Old 12-14-2008, 07:34 PM
KC36330
Enlighten me, i've been flying my jets with a modded Heli version 10x but recently got one heck of a deal on an aero version, the only temp push button on it is the snap roll/trainer button.............how are you using this for smoke on off?
EDIT: Never mind, figured it out!!!
Old 12-14-2008, 07:55 PM
Skymac
My Feedback: (8)
Skymac's Avatar
What about a firmware upgrade that enables putting the trainer switch somewhere else besides the two gimble switchs? It's got to be one of the most uncomforting things to hold, not to mention if your gonna do it on a heli then you have to turn off either the throttle or pitch trim.
Old 12-14-2008, 08:04 PM
MLaCoste
My Feedback: (15)
MLaCoste's Avatar
John-
My LHS just received a 12X last week. How can I check to see if it has the latest version of the software?
Thanks!
Mark
Old 12-14-2008, 08:18 PM
ddennison
My Feedback: (15)
I have the same question as Mark above. Mine is a fe wmonths old and I already had to send it in twice: once for a broken antennae (arrived that way) and second time was for the throttle detent.....
I saw a post here regarding making the "trim" switches on/off, I don't remember if that was something that had to be held or just "triggered". I like my 10x button for brakes!
Anyway, if anyone can calrify that would be great or I will likely ask that HH check mine too.
thanks
Dave
Old 12-14-2008, 11:37 PM
SinCityJets
ORIGINAL: tclaridge
It is just one of the setting on your timer. Go to your timer screen and adjust one of the three or four settings. When I get my redio back from Horizon this week, I can tell you exactly which one you need to change.
Old 12-15-2008, 09:37 AM
John Redman
My Feedback: (8)
If your hobby shop just got one it has the new software. The only 12X's that did not have the current software were a number from the initial shipment. A fair amount from teh first shipment had the new software. There is a manual addendum you can download from the Horizon web site explaining how to make the trigger switches on/off with one click.
Old 12-15-2008, 09:51 AM
Gordon Mc
Perhaps future versions should be modified to be able to display their firmware version info on-screen, so that people can easily tell which one they have.
Old 12-15-2008, 11:00 AM
MLaCoste
My Feedback: (15)
MLaCoste's Avatar
ORIGINAL: Gordon Mc
That's kind of what I was hoping for....
Mark
Old 12-17-2008, 11:00 AM
FlexEm
John
will the software upgrade make the trainer switches off/on when using a buddy box, it is a pain trying to hold that switch down for 8-10 minutes. Or is there a way to move trainer switch to another off/on switch.
Freddie
Old 12-21-2008, 10:10 AM
tclaridge
tclaridge's Avatar
Timer problem solved. OK now I just feel silly. My throttle hold is set to the mix switch. This makes a great engine on/off switch. Then I set the timer to the Mix switch. Problem solved! I was too caught up in trying to trigger the timer with the throttle.
Old 12-21-2008, 11:10 PM
SinCityJets
ORIGINAL: tclaridge
Got my transmitter back. You are taking the long way around.....Turn the "One Time" to ON....it is OFF by default. That will solve your problem and get rid of the mix.
Old 12-21-2008, 11:40 PM
tclaridge
tclaridge's Avatar
SinCity, "One Time" under which menu?
Old 12-22-2008, 12:01 AM
SinCityJets
The timer menu (87). Put the one Time to ON.
Old 12-22-2008, 10:22 PM
BlackCloud
My Feedback: (12)
BlackCloud's Avatar
Hey Chad,
When did you send yours in? I haven't gotten mine back yet and they should have had it in hand on the 12th Fedex.
Starting to wonder where it is......but then again......Black Cloud...what else.......or where else is it
Mark
Old 12-23-2008, 12:09 AM
SinCityJets
Mark,
They RECEIVED mine on Dec 3rd. I got it back last week some time. I think you have a little bit to go. You can always call them to check on the status. They were always friendly and helpful when I did.
Chad
