Wren Users
RE: Wren Users
I know weight is weight, but from experience dont waste your time with the wand. If you can fit the FOD screen and starter set up on your engine in your installation for 5oz, do what we do with the manual start turbines- just have an external battery pack with a deans plug or a neat electrical plug of your choice with the other end obviously soldered into the wire going to the starter motor. works a treat. Install a micro switch so you can vary the speed/ initiate spooling the turbine on start or whilst cooling proportionally to pressure when depressed. Wand works fine, but its a lot easier to pop your hatch, connect the external battery up and start/ cool turbine than fiddle around trying to make square contact with the wand on the compressor nut. My 2 cents worth.
Cheers.
Cheers.
RE: Wren Users
I'm with essendon 05. I have a pair of 44's and converted one of them to FOD screen/on board starter, I would not even bother about the 5OZ.
If you are desperate to save the weight the wand starter is literally just a motor on a stick, just remove the starter housing, put a handle on it, lock the clutch up & away you go.
After seeing the starter O ring fall out of the wand starter & roll around inside a model close to the intake of a running engine [X(] I made up my mind that there had to be a better way. - John
My Feedback: (46)
RE: Wren Users
I have had both types of starters on my engines and don’t mind the wand start at all. I have 3MKIII now, 5 oz doesn’t seem like much weight to some, but when you are at 15 lbs 12 oz dry weight on a plane with 620 sq in of wing every little bit helps. George
RE: Wren Users
George- I am in the process of converting my TG F-15 to turbine using my RAM 500. The original starter on the RAM has been a problem and the cost to convert to the heavier Bendix is nearly $300.00 so wanting to save money and weight and add a FOD screen I made my wand shown below. I have made two bench runs with this set up but has not been flown yet. Picture No. 1 is with FOD screen in running position. Pic #2 FOD screen is hinged and shown in start position. My Start Wand has a fiberglass shell that fits the nose of the RAM 500 to hold it straight during the starting process. I plug the Wand Starter motor into the normal starter cable of the ECU so I can use the normal auto start feature. The rest of the pictures are the starting wand.
I hope to fly the F-15 at Chatfield when we get some flying weather.
RE: Wren Users
I have a wand here somewhere, which I do not use. I sent mine back in and had them add a third line which I hook to a compressed air tank. I use compressed air, it works much better than the starter wand, and you can hook it up to cool off the engine when you shut it down. If you are desperate for a starter wand, let me know and I will see if I can find it for you.
My Feedback: (21)
RE: Wren Users
ORIGINAL: aquaskiman
I have a MKIII in a starfire and want to use a wand starter to save the 5 oz that the FOD and starter weigh; Ron Ballard has told me that they are not available any more. Does any one know where one might be found? Thanks George
I have one that I would be willing to part with. It came from an mkII that i switched to full auto start. Drop me a PM with your Phone #
Joe L.
