Raptor G2 Pitch
My heli will barely lift off at almost full throttle. I have tried everything in about wetting the pitch but none seems to work. When I turn on dip#10 and unhook the motor and plug everything up the V1 knob doesnt change anything please help. I dont have a pitch meter but the head speed is plenty high enough.
TN
I had the same problem with mine. The helo was at full throttle and barely lifted!!! I went back, took my rotor blade holders off, and put them back on. Come to find out, the blade holder was not positioned correctly on the rotor head. With the G2, the main blades seem to point indirectly toward the ground instead of being level like most helos. After I adjusted it, I lifted off at a little past 50% throttle. Most importantly, ensure the blades are tracking right! If not, it will have difficulty in getting off the ground. Hope this helps.
it is 100% ready to fly and I'm sure your setting was changed without you knowing it. More importantly don't give up and don't blame the helicopter. help is available.
ANdy
ANdy
