TRX 2.5 Problems
TRX 2.5 Problems
Recently put my truck back together and I have been having problems running my motor. This is weird to me because I did not change anything in the engine. I cleaned it off with some simple green and some Q-Tips and that is it. The idol is really high even with the idol fully reduced, honestly I think it is a problem with the linkage, could this be the source of the problem? My brakes are really messed up too, I will pull the brake and nothing will happen, the servo will move, but there is no brake applied. I need to tinker with the set up. Does anyone have a top down picture of a T-Maxx 2.5 so I can see where the little set screws go. Another problem I have been having is that the pull start is almost impossible to pull. It will pull once or twice, then get really tight. The only way I have been able to get it started is so loosen the glow plug and let some of the pressure out. I have to leave the glow plug loose until it gets running then quickly tighten it back down. What would be causing this to happen?
Any and all help is appreciated!
Sorry I kind of rambled...
RE: TRX 2.5 Problems
it being hard to pull is usually cause buy a flooded engine or maybe your engine is all gunked up if you haven't ran it in a while. Try to take your glow plug off and pull the starter with the car upside down to clear it out. Also use the traxxas website. They have an excellent FAQ page and also all the pictures and diagrams you need.
ORIGINAL: superman11
Yea, I did that, it did not work... not flooded. How do I know if it is gunked up? How do I clean it?
Good idea, but I am not sure I am confident enough to take the entire engine apart...
ORIGINAL: scarletboa
i think it's just your linkages. fix those and then try starting it again.
MA
Spray it with wd 40 to clean the OWB. I too would suspect the truck is probably rich if after a couple pulls its locking up. The brake should be placed in the middle of the 5 holes on the servo horn. Get rid of the spring on the brake if you have one and use fuel tubing . Try leaning the lsn a little to see if it will crank.( I'm a cheater) If so put need back to previous setting and Lean the hsn till it starts. Then retune. From HSN to LSN then Idle. You want smoke at every throttle pull and no bogging. If I confused you a little pm me and I'll clear it up. Go to get you running Super. Wish I was still in Duval enjoying the weather like you.
Ok, I will... Do you think that it might just be a problem with the OWB with like build up? How do you clean that?
