Battery size for SuperXtra
Hey John I am waiting for the super Xtra I ordered and was working out details of building it in my own mind before it arrives, my question is what size battery (in mah size) do you reccomend for the superXtra, the mtor specs call for a 1200 to 2100 mah 3s lipo. I have a set of micro digital servos I plan on using and would like the most battery life without making it fly like a tank. Your recomendation would be appreciated.
Thanks again en1...
If it matters I ordered the Hacker A20-20L also with a 20 amp speed control....
Thanks again en1...
My Feedback: (38)
RE: Battery size for SuperXtra
with that power setup Ive used 1200mah (throttle sparingly), but recommend 1600mah or so, 2100 is in my opinion too big. Ive gotten 12+minute flights out of a 1200mah, only time you need full throttle is a vertical upline, all 3D is done from 1/4 to 1/2 anyway.
Well thanks for the input I may try it ...I also have access to some 1350 thunder power batts I can try then. If I need to I can buy a couple of the right size....Well I cant wait to see this thing I have landing gear and servos everything else is coming so now to work on paint scheme.....
Thanks for the fast response .... and your help....en1....
