Feda/Skylark
The circuit board on my new Skylark only has one red LED. It blinks while setting up and then glows steady when ready to fly. My question is that there is only one trim pot on the circuit board. Does anyone know what it controls or have any other info on this unit????
DC
it probably controls the tail gain, or in other words how much current goes to the tail motor when the main throttle is in a certain position. if the board has a build in gyro then it is the gyro gain pot, which adjusts how much the gyro conpensates for detected movement. on my piccoboard there are two pots, one for tail gain the other for gyro gain.
hope this helps
cheers
hope this helps
cheers
You must have the newer version of the skyark. The version that I have has two pots which control the neutral position and the gain. If you only have one, my guess is gain. This is only a guess, but most likely, if you turn it clockwise, your heli will rotate more right, counter-clockwise and will rotate more left. You use this if it still spins with max trim. Idealy, you want to be able to turn it on and only trim about 1 or 2 'ticks' from center.
Also, I don't have a FEDA, but I'm almost certain it is not the same as a Skylark despite what others say. If it didn't come it a box that says Skylark on it, then I have no idea what electronics are on it and what I said is probably not valid.
I have the same model as yours and I seem to have the same problem with torq control I'll check to see what the setup is on the mixer board and let you know what the results are.
EricMS,
I have attached a pic of my FEDA board with 2 pots, is this the same as the board you speak of?
If so which pot is which
Steve
Steve
My Feedback: (58)
Steve,
I don't think your board has any trim or pot. Two adjustable things on your board are the inductor coil, and one is used to select frequency (the lower one) and one is used for antenna matching imedance. Do not adjust these coils, or you will loose control of your heli. Unless you have the scope to set it back. I hope this would help.
MTDV.
MTDV.
