Skylark main rotor blades
I broke one of my skylark main rotor blades. Can I use a piccolo or hummingbird main rotor blades instead? cuz the price of the skylark blades is $27 while the piccolo is merely $18. If anybody is using any of these blades in their skylark pls let me know. thanks in advance.
dave
dave
Originally posted by plane_pilot
Take a look here:
http://centuryheli.com/products/heli...lacement01.htm
$15 for a set of blades.
Take a look here:
Skylark Blades
The Skylark blades have a smaller mounting hole that either the Piccolo or the Feda blades. The Piccolo blades will work on a Feda MiniDragonfly or Century Hummingbird if the hole is enlarged slightly. I have Skylark blades (as well as all the other parts) in stock at what I think are reasonable prices (the Skylark blades are a little less than the Feda/Hummingbird blades). Let me know if you want me send you price list.
Dan
Dan
Danand,
pls send me the price list of all the skylark parts thanks! send it to me at [email protected]
This seems to work for me to reduce start-up vibration:
1. Secure, BUT Do not overtighten the Rotor Blades to Rotor-Hub screws.
2. By Sight, Adjust the Main Rotor Blades to be as perpendicular to the Flybar as possible.
3. Grasp each Main Rotor Blade Tip-End and pull (Gently Yank) outwards. This seems to equalize them and allow almost-vibration free start-up. Then, during run-up, the blades will quickly 'adjust themselves' and smooth-out.
