Has anyone seen this?
OH
[link]http://www.hobbyetc.com/cgi-bin/item.cgi?part_id=57641;photo_id=70638#ilikepicture s[/link]
I think there are great possibilities with something like this. I have always wanted a E-Maxx for the "no mess" easyness of it.
What do you guys think?
NC
RE: Has anyone seen this?
ORIGINAL: superman11
That is a great idea! You can run nitro while your batteries are charging! Except where do you put the batteries?
The following pics and info are from Hot Racing
TRX Class Electric power conversion $88.88
Hot Racing electric motor conversion kit was designed around a Traxxas 3.3 class nitro engine.
FEATURES:
* Direct Bolt-On - no additional modifications necessary.
* Easily keep up with the nitro counterpart
* Work on Any car or truck use Traxxas class nitro engine.
* Faster acceleration
* Light weight for higher top speed
* Predictable performance
* Highly versatile system for high RPM or high-torque low RPM applications.
* Full Ball Bearing.
* All hardened steel gear
INCLUDES:
One Traxxas Class Electric motor adapter
REQUIREMENTS:
brushless Motor (stranded motor can size only), ESC and battery
Pinon Gear (32Pitch) for electric motor
Use All Stock Clutch flywheel and, clutch bell.
simple hand tools for installation
ESC Reverse Disable
Lubricants For steel Gear.
FEATURES:
INCLUDES:
REQUIREMENTS:
ESC Reverse Disable
ORIGINAL: thesouth1
^^^^Yeah... thats what is in the link I posted when I started this thread.....^^^^
I thought it would be easier for people to see what the link was refering to, instead of having to click on the link and waiting for it to open.
NY
Good idea, but you would still need the mechanical brake in order to stop, which will make setting the ESC interesting, to say the least. My big question is how well it holds up.
OH
I really appericate you lookin out, t9dragon. I was just going to post the pic eairler today but it copied it in BMP. and RCU dosen't let you paste BMP. so I just linked it.
Just use a esc from a E-Maxx and it has a no reverse setting, if I am not mistaken..
Original:straick
OH
Are you still using the clutch shoes or is the clutch bell always engaged now? If this would replace the clutch shoes with a direct drive then I would think the ESC brake and reverse would work for both of those operations. If this keeps the clutch then you would have to keep your throttle/brake servo and it is going to be one big mess to get everything to work.
