How can i get speed? ? ?
I have a Aeromarine conquest, this is my first boat (or 1st R/C ever), me and my brother in law are building the same boat, but my question is simple what can i do to make mine a little faster.? ? ?[>:]
RE: How can i get speed? ? ?
If it's the same setup, spend time trial and error testing on the water with a gps will be the only true way to get an edge over your brother. By tuning, I'm talking different size props, hardware trimming, c/g adjustments and even small changes in the needle setting on the carb. Besides that, your only other option would be to get a more powerful engine (along with the previously mentioned tuning.
Oh yeah, welcome to RCU! You've found the best place to begin, we've got your back! Read through the threads and you'll be surprised what you'll learn.
Certainly having the boat set up well from the get-go is never a bad way to start. Are you building the boat yourself or is this something your buying built. If already built - is it from Aeromarine or a previous owner. If you have some pics of the transom (back) and the motor/pipe setup we might be able to offer a fer other pointers that may help you in your quest for the edge
TN
Model Gas boats .com has a great build article on the Conquest. I would follow that article except for mounting the strut inside the boat. I'd keep it on the transom.
Props are very important. A friend of mine has a conquest. It seems to like a 6717/3 blade 420 best.
I have heard that this boat is capable of mid to high 60's but we have only had his up to 55 mph. I think we should be able to break 60 with more tweaking though.
I think it's an excellent hull.
What engine are you putting in it?
My Conquest does upper 50's in tight oval trim, loose it does mid 60's effortlessly.
Prop choice is a MAJOR issue in getting some decent speed, as is a good mod engine and a good pipe.
A GREAT prop for the boat is the Propshop/VooDoo 7016/2
