Aircraft servo set up
My Feedback: (24)
MO
Hi,
I have a 33% Weeks Solution with a G-62 and need some advice regarding the radio setup. My plan is:
2 servos on rudder
2 servos on elevator
1 servo per aileron (4 total) and
1 throttle servo. 9 all together.
Now, should I use two receivers and split the channels? For example one receiver for top ailerons and 1 receiver for bottom ailerons. Or should I just "Y" harness all four aileron servos together into one receiver in the aileron slot?
What receiver battery capacity would you use? What linkage parts?
This is my first big airplane and I'm looking for help.
Bill
2 servos on rudder
Bill
RE: Aircraft servo set up
ORIGINAL: mackey1
Hi,
2 servos on rudder
Bill
Hi,
2 servos on rudder
Bill
1. What type of radio are you going to install?
2. what type of servos are you installing???.
3. How many channels on your receivre
Need this info before most people can help you with any type of set up.
