TC3/TC4 Tires for high speed
I am almost 90% sure Im going w/ the castle Mamba 5700kv and 3S LiPO (or close to that setup) for my TC4 in an attempt to see 70+ mph... the tires I had were local hobby shop ones on decent rims on the thing w/ the 4600kv and 2S LiPo and it shredder the rubber right off the rims. What tire/rim setups are you guys using and would you recommend for this attempt?
WI
RE: TC3/TC4 Tires for high speed
Use foams. Also you can get adapters so you can run pan car rear tires, giving you a much larger contact patch. But either way use foams.
