Smoke Setup
AR
Smoke Setup
I tried to search this subject but could not find anything.
I am thinking about putting a smoke system in my plane and wanted some opinions and details on how to do this. Does anyone have any links to threads here on RCU?
rc-plane
rc-plane
RE: Smoke Setup
http://www.sullivanproducts.com/S753...structions.pdf
Here is the paper work that came with my sullivan pump and I followed it to the T and had no problems.
Hope this helps,
Kevin
Hope this helps,
Kevin
AR
RE: Smoke Setup
thanks, I am kinda looking or a thread RCU with some pics so I can kinda see what kinda of room it will take and were I need to put it.
RE: Smoke Setup
Smoke goes faster than fuel. So you need a tank pretty much equal in size or larger than your gas tank. A smoke pump takes up only slightly more room than a standard receiver. Ideally you will use a separate battery for the smoke pump.
Any of the leading smoke pumps work very well. Going to any of their websites will provide instructions of how to set one up. The instructions, if followed, work every time.
