Battery help
Old 02-24-2009, 02:11 AM
outofreach
Default Battery help
I bought new Tenergy 5000 1.2 volt nimh cells. I made 1 - 8 cell pack and 1 - 9 cell pack. I soldered everything and used the deans bones to connect them. Everything seems to be connected good and i'm charging with the Prophit Plus 2 charger. The 4600 7 cell packs that I bought have twice the power and last twice as long. Did I buy bad batteries? Is the charger I got to small for these packs? Do I need to do anything special to the new batteries, they have went through a few cycles and still suck.
Did I ruin the batteries? What charger / decharger should I get?
I would appreciate any help you can give me. I know i'm new and a pain but trying to get these working.
Joe
Old 02-24-2009, 02:14 AM
redfisher1974
redfisher1974's Avatar
Default RE: Battery help
Nope the tenergy's are just cheap low end cells....
Old 02-24-2009, 03:19 AM
outofreach
ORIGINAL: redfisher1974
That was very helpful
Can you point me in the right direction? What cells do you reccomend?
Old 02-24-2009, 09:32 AM
redfisher1974
ORIGINAL: outofreach
sorry i was tired...Anywho Elite cells are good so are Ener-g cells are awsome and IB cells
I just had a custom pack made by Cheapbatterypacks.com with Elite 5000mah's for $47.
Old 02-24-2009, 09:34 AM
Druss
Tenergy are lower end cells but should still last as long as the others. Did you do 2-5 forming cycles charging at 1/10C?
Old 02-24-2009, 09:50 AM
savagecommander
i have a prophet charger and lets just say i dont use it anymore- mine wiould heat the cells really bad when charging.
Old 02-24-2009, 12:07 PM
outofreach
So i'm getting a new charger, any reccomendations?. I guess I want to be able to charge Lipo''s, 9 cell nimh packs and charge and discharge>
I didn't form the batteries. I will get a new charger and do that but is it too late? I guess i'll form them and hope for the best.
Thanks for the help.
Old 02-26-2009, 01:33 AM
outofreach
Is there any way I can change my post count to say 423,835 posts?? So I can be considered cool and worthy of assistance?
Old 02-26-2009, 10:45 PM
Druss
The best bang for the buck quality charger I have is the Thunder Power 610C. It will charge ANY type of battery including up to 6S lipos at a 10amp charge rate. Comes with a built in balancer for TP and Align taps. Needs a power supply though.
Old 02-28-2009, 04:36 PM
outofreach
Thanks for the info I got the Thunder charger. I have one more question.......
I made a Tenergy 9 cell pack so I think that is 10.8 volts??? I cycled the pack 2 times discharging to 9 volts and it automatically charged it to 13.6 volts, does that sound right??
I now know I made a bad choice on the battery selection. I bought a Lipo pack, just trying to get the ones I made working so I can give them to my nephews.
Thanks for any help.
Joe
Old 02-28-2009, 05:13 PM
redfisher1974
Thats about right it took it down to 1 volt per cell(.9v is the lowest you would want to go)
And the finish volts is always higher...If you let it sit for a while then check it again the volts will be lower.My 7 cell 8.4v pack is around 11.5 volts fresh off the charger.
You are doing everything right.
Old 02-28-2009, 05:47 PM
smity80
I bought the Onyx 230 by duratrax it has a 10 batt memory adj from .1-7a charge, good display showing amps,charge rate,and mah for charge and will charge all batts. only about 80.00.
Old 02-28-2009, 10:41 PM
mazdaprotege4
My Feedback: (32)
Is that truck in the photos yours? If so that is one sick truck, is there anything stock left on it?
Old 03-01-2009, 01:34 AM
outofreach
Thanks for the help, I think i'm finally getting it.
Ya the truck is mine, its a ( or was ) rustler. Nothing is left from the truck except the motor and esc, nothing. I think I got a little carried away its kinda heavy now, but I liked building it. Its Fast Lane, Integy and I built a fair amount of the aluminum parts as-well. I think lighter is probably better but is still does pretty good.
So while i'm on the question thing.....
What would be the sickest 1/10 scale off road I could build, lighter this time. The fastest, most durable, well balanced for big airs, whats the best?
Joe
Old 03-01-2009, 10:52 AM
Wild YFZ 450
Wild YFZ 450's Avatar
slash
Old 03-01-2009, 12:16 PM
qoisdhc oqina
My Feedback: (-1)
qoisdhc oqina's Avatar
yeah outofreach.post 423,835 posts.
Old 03-01-2009, 12:38 PM
DeaconBlues
i hope this is on topic enough, i went lookin around to find out what the s in 3s 4s 5s etc.. lipo meant. that is explained here [link=http://www.rcslot.com/blog/lipo-batteries-explained-a-how-to-guide-for-lithium-polymer-batteries.html]3s 4s explained[/link]
and some information on charging, care, and safety with lipo packs. quite a few informative videos on them exploding under certain circumstances.
[link=http://www.rchelisite.com/lipo_battery_charging_and_safety_guide.php]lipo battery charging and safety[/link]
i hope this helps someone.
http://www.rcslot.com/blog/lipo-batt...batteries.html
http://www.rchelisite.com/lipo_batte...fety_guide.php
