JR 12x as a Sequencer
My Feedback: (9)
I thought I read somewhere where the new 12x can act as a sequencer by allowing you to control servos speeds each way. Is this possible? Can someone point me in the right direction or care to elaborate on this for me.
Sean
Sean
RE: JR 12x as a Sequencer
on the 10x it's code 24 SPEED.
EDIT: Just looked it's code 24 on the 12x too.
for say sequencing gear/doors ..........from the retracted position you want the doors to move fast on the down, and the gear slow on the down..........from the extended position you want the servo fast on gear up, slow on doors closed.
My Feedback: (9)
Yeah on the 10x its an all the time slow, so your sequence works one way but not the other [X(]. I was hoping someone could elaborate on the BI-DIRECTIONAL functionality of slowing the servo down and how to go about accomplishing this.
thanks
sean
thanks
sean
go into code 24, highlight the channel AND direction you want to adjust, then use the roller wheel to adjust it. you can adjust the speed in both directions. you'd want them activated via the gear switch (position 0 and position 1)
