a xtm nitro the one way bearing wont stay on piston rod its not broke remove and reinstall pull star
i have a xtm nitro the one way bearing will not stay on piston rod am i putting it on wrong
RE: a xtm nitro the one way bearing wont stay on piston rod its not broke remove and reinstall pull star
remove and reinstall pull start works one time only
ON, CANADA
It wont stay on because the fit on the bearing and pocket isn't tight enough?
do i need a new bearing then or what? thanks
ON, CANADA
I'm asking if thats whats causing the problem. If it is try leaving the bearing in the freezer for a few hours and heating up the crankcase. Reinstall the bearing as normal but wrap one or two layers of tinfoil around it to take up the play. This is a temporary fix.
