OS 50 SXvs Saito 72 for 3d
Besides hovering from both planes since its possible. Which of the engines you experience in comparsion from both.
I had a best experience with the OS 50 SX when I used 11 x 4 APC. I spools up so fast that I can do alot more when it comes to flat spins and other spinning type vertical maneuvers.
Now that my Giles 3d is gone from structual failure. (fuse split in half from a forward flight to a quick vertical hover.)
Im thinking of h9 FUNTANA.
Should I stick for my same engine or get the Saito 72 for the Funtana
Ys63 is not an option for me since I dont want to spend more $$ on fuel, shorter time on warranty.
Thanks for comments and thoughts
