3M Spray Adhesive
3M Spray Adhesive
Old 06-13-2003, 11:29 AM
BUTCHMAN-RCU
Default 3M Spray Adhesive
I just read in the latest RC REPORT that 3M has changed the
formula of their adhesive in 77 to be environmentaly safe.It now
EATS STYROFOAM.So beware of using it!!!The new stuff is in spray cans with NO red stripes,just a red tint.
Old 06-13-2003, 12:10 PM
Hinckley Bill
My Feedback: (569)
Default New ingredient in 3M adhesive
Yes, the ingredients in the 3M adhesive spray changed well over a year ago actually..
I believe the product used to contain the chemical toluene but thanks to California Prop 65 and EPA VOC issues they had to remove it and so they went with a "much safer" chemical....acetone!
It's the acetone that's the problem, so if you're unsure of whether the can is new or old just check the labeling....acetone is clearly spelled out on the new cans, while I believe toluene should be on the old...
Bill
Old 06-13-2003, 01:53 PM
GarySS
My Feedback: (13)
Rats.......3M was so good to use on foam wing cores and sheeting plus other uses.
What is a good substitute?????
Old 06-13-2003, 01:56 PM
Deadeye
Deadeye's Avatar
It will still work on foam, as long as it is put on in very light coats. Saturate it, though, and it will be eaten.
Old 06-13-2003, 05:27 PM
Backwing
Tolulene(sp) is a chemical that is great for cleaning parts and what not, but it can also be used for making meth and or some other drugs. I assume this is a reason for it's discontinued use. Although I'm sure the bunny huggers had something to do with it also.
Old 06-13-2003, 06:13 PM
TOYMAKER
Default ACETONE
So acetone is safer huh??? I though the it was easily absorbed through the skin and is hard on the liver and nervous system.....twitch, twitch!!!
So far the best stuff I have used for sheeting wings is Elmers Probond Urethane. Hands down.... thumbs up...
Wayne
Old 06-14-2003, 12:03 AM
Roquewj
Acetone is the basic chemical to refine cocaine. So this is not the reason for discontinue using tolulene. Must be other environmental reason.
Old 06-14-2003, 12:05 AM
Goggles
Goggles's Avatar
I don't know if it's of any use to anyone, but in Canada 3M did not change the formula. I used it on a current project with no problems.
Old 06-14-2003, 02:01 AM
rajul
Moderator
My Feedback: (58)
rajul's Avatar
Thanks for the alert ! Gotta check out what's in my can of 3m 77.....
Old 06-14-2003, 03:33 PM
TOYMAKER
Default acetone
Originally posted by euqor
Acetone is the basic chemical to refine cocaine. .
Well better get rid of all my acetone in the garage before my wife suspects me of doing something illegal... <VBG>
hmmmmm I wonder if good ole smelly Butryte dope will ever make a come back?
Old 06-14-2003, 04:10 PM
LoboFlyer
Actually, I believe that acetone is a carcinogen as well
Old 06-14-2003, 11:54 PM
rajul
Moderator
My Feedback: (58)
rajul's Avatar
Just checked the label on my can and it sure is acetone instead of toluene.
Old 06-15-2003, 12:17 AM
KJohn
I have two untouched 16.5 ounce spray cans here. It mentions items it will 'securely bond', one of which is polystyrene foam.
The ingredients are listed as:
nonvolitile components, 2-methylpentane, dimethyl either, isobutane, propane, methylpentane, 2,3-dimethylbutane, 2,2-dimethylbutane, n-hexane and other hexane isomers.
I don't see the word 'toluene' on the cans.
I forgot I even had them.
Old 06-19-2003, 07:46 PM
FLYBOY
FLYBOY's Avatar
I quit using it years ago. It was great for foam wings, but has some of the highest cancer causing crap in it from what I hear. I use 3M #924 transfer tape. It works as well as anything I have ever used. I like it. Use it on everything from 1/2 A to my 135 inch wing gliders. Never had it unstick.
Old 06-20-2003, 11:42 AM
CCRC1
My Feedback: (13)
CCRC1's Avatar
Tolulene is the chemical "huffers" look for in aerosol cans to get high. Thats why products with it are being scrutinized. The product is sprayed into a plastic or paper bag and the fumes are inhaled. It was the chemical that was used in model airplane glue back in the 70's before they pulled it from the market and changed the formula. How many of you remember those days? Went to the hobby shop and all they had to sell was stuff that smelled like lemons. You could get a better bond with Elmers glue!
Old 06-20-2003, 05:54 PM
TOMMYSTA
My Feedback: (15)
Default TRY THIS
If you need a spray contact cement try 3m's trim adhesive spray...#08074. It wont attack foam and it seems to have a better grip than the 3m77. I've used both when sheeting and i prefer the 08074. Then I read in Model Aviation during that large Extra construction article that the builders alos used 08074.
Give it a try!!!!
Old 06-21-2003, 09:13 AM
the_knack
I've heard that DURO makes a spray adhesive that is a replacement for the 77. Anyone know anything about that?
Danny
Old 06-23-2003, 03:39 PM
KevinSheen
I bought some of the Duro spray adhesive, Acetone is one of the ingredients.
Kevin
Old 06-23-2003, 04:30 PM
Tall Paul
Be sure to try anything on a piece of foam you don't want!
I have a sheeted wing with the foam collapsed inside after it melted the foam.
Flies, but not the greatest.
Old 06-24-2003, 09:07 PM
ianober
My Feedback: (12)
ianober's Avatar
Sig makes a pretty good "contact cement" type product that works great for balsa sheeted foam wings. I think its called Sig Bond. WOrks really well if you follow the instructions on the can. However it doesnt work well for the foamie gliders which is where I will miss the 3M the most!
