Checking Voltage on Fromeco Regulator
Old 03-29-2009, 11:26 AM
Harleyflyer
My Feedback: (9)
Harleyflyer's Avatar
Default Checking Voltage on Fromeco Regulator
Can someone tell me how to check the voltage coming out of a Fromeco regulator? I know how to change the voltage using the two pins on the side. I'm just not sure how to check the voltage it is being regulated down to. Right now I have the 2600 lithium battery and the regulator plugged into a switch.
Thanks in advance,
Keith
Old 03-29-2009, 11:38 AM
Harleyflyer
My Feedback: (9)
Default RE: Checking Voltage on Fromeco Regulator
One other thing I should mention is that the other wire coming out of the regulator I am wanting to check has been soldered to the wire going to the ignition for a DA 50.
Old 03-29-2009, 12:56 PM
sweetpea01
My Feedback: (10)
I have a H9 inline volt/amp meter.
I use that the same way. You plug it inline from the reg to the RX and it will tell you. Handy device for setting up servos as well
Old 03-29-2009, 02:44 PM
krayzc-RCU
My Feedback: (31)
plug a voltmeter on the other end of the reg and turn the switch on if you have already connected it to one. the voltage u see on that end is what you have regulated it to....[8D]
Old 03-30-2009, 12:11 PM
Harleyflyer
My Feedback: (9)
Great......thanks guys....I appreciate the information!! [8D]
